Relocating The Thermostat.... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 05:16 PM   #1
Rewards Points: 56
Question
Relocating the Thermostat....
Hi all,
Newbie to the forums and a new homeowner too. It looks like I will need to remove a wall in my new place to open up the space and lay out my furniture properly. My question is, since I will need to relocate the thermostat to complete the job, what do you need to do to relocate it? I mean, I can run wire pretty good, but do you shut the furnace down while you are rewiring the t-stat?
Thanx!
Don
donste2010 is offline   Reply With Quote
Old 01-20-2010, 06:21 PM   #2
Electrician
Rewards Points: 780
If it is low voltage no need to turn it off, maybe tape the wires for they don't short on each other.
Make sure you label the wires as well when you take it off the stat for you can easly reconnect it once you move it.
darren is online now   Reply With Quote
Old 01-20-2010, 06:28 PM   #3
I would turn the power off, whats the big deal about doing so, if it`s a newer efficient furnace the main control board could be easily messed up if you hit the wrong wires together.
journeymanj is offline   Reply With Quote
Old 01-20-2010, 08:30 PM   #4
Weekend Warrior
Definitely turn the power off. If the thermostat wires were to short out, it could take awhile to find the burned-out fuse inside the air handler. Ask me how I know...
H2O Engr is offline   Reply With Quote
Old 01-20-2010, 10:08 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
It's probably also not good to cycle the furnace on/off many times in a short period, which may happen while the bare wires are handled and pulled through. Just shut off the power to the furnace to be safe.
Old 01-20-2010, 11:02 PM   #6
Before disconnecting ANY wires from anything, always label which wire goes to what!
Stick self adhesive paper address labels to each wire or whatever.
Take a picture of which wire is going to which connection.
Also might want to make note of which end is up on each part of the thermostat if there are several parts to remove.
Billy_Bob is offline   Reply With Quote
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
