Relocating Oven Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 05:26 PM   #1
Relocating oven circuit
Hello. I have a kitchen island circa 1985 that has a Jenn Aire electric cooktop installed when the home was built.The power, 220, comes up through the floor into the island. I am now going to eliminate the island completely,install a new wood floor to cover and switch to a gas cooktop on another part of the counter and add a double electric oven. My question is can the 40a circuit service wire used for the island cooktop be extended, through the use of a box in the crawlspace, I suppose, about 10 ft to the wall where the double electric oven will be?.The house is on a crawl space so there is fairly good access to the wire. Can these wires be extended a short distance or do I have to do what I think I have to do. Thanks.
bonehead2 is offline   Reply With Quote
Old 01-31-2009, 06:25 PM   #2
Licensed electrician
Rewards Points: 996
It wouold depend on the number of conductors that currently feed the old setup. New installs need a 4 wire circuit.
The ampacity would also have to be the same or greater than the new equipment.
Old 02-01-2009, 01:08 AM   #3
Generally, a double oven needs a larger circuit than a cooktop (40 to 50 amp as opposed to 30 amp) Just because the breaker is a 40 amp doesn't mean that the circuit is a 40.
Check wire size. If it is #8 copper, your double oven will work.
Can you use it for a new installation? Gray area. New installations require a 4 wire circuit with the neutral (white) and ground (bare) seperate. Older installations allowed a 3 wire circuit combining the neutral and ground. If you wre simple replacing the unit, no problem, code would allow it. Since you are moving it a bit....gray area in most cases.
220/221 is offline   Reply With Quote
Old 02-01-2009, 10:48 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If your new oven is only 240 volts and not dual voltage 120/240 and meets the requirements for a 40 amp branch circuit as 220/221 said I see no reason why you cannot extend it. If it requires 120/240 and the existing branch circuit only has 3 wires I don't believe it would be allowed to be extended. Only your codes department can approve it one way or the other.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-03-2009, 11:06 AM   #5
Thanks for the help. I had an electrician come over and he said he could extend the wire without much problem at all whether the new oven is 3 or 4 wire. It's #8 wire so he said it will run the double oven with no problems.I don't know if the new oven needs split voltage though, he said not to worry.
Hope he's correct.
Old 02-03-2009, 12:34 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
There isn't any thing that prevents him from extending a 3 wire circuit for 240 volts. There also isn't any giant danger in extending a 3 wire circuit for a 120/240 volt appliance. It is however a code violation unless your local code department will sign off on it. 4 wire branch circuits are now required... to be able to remove the neutral to ground bond of the appliance chassis and they offer a degree of safety over 3 wire connections.
Stubbie
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
