Old 06-26-2012, 10:58 AM   #1
relocating older 220 dryer outlet: what is allowed?
I have a wall open for some work and wish to relocate a older dryer outlet.
-It is an older three wire.
-cable looks in very good shape
-there is slack for me to move it the two feet needed.
- new pull of 4 wire is cost prohibitive.
I understand moving these outlets is allowed.
I am not clear if replacing the receptacle and or box is allowed while relocating. I would prefer to, especially the receptacle. I have both new. Is this allowed?
thanks
rasz is offline   Reply With Quote
Old 06-26-2012, 12:06 PM   #2
J. V.'s Avatar
Yes. As long as you are not adding any cable, you are fine to move the receptacle anywhere you like.
Old 06-27-2012, 09:18 AM   #3
JV, thanks. Perhaps I wasnt clear. I already know I am allowed to move it as long as distance is equal or shorter to preserve existing wiring.
the question is: while moving it, can I replace the box and receptacle/outlet with new equal to existing components, or is that not allowed under grandfathering?
I have a new in box Pass and Seymour 3 prong 220, and a new junction/outlet box on hand.
Old 06-27-2012, 09:22 AM   #4
Licensed Electrician
k_buz's Avatar
Sure, you can replace existing parts without having to repull the circuit.
Location...Location...Location
Old 06-27-2012, 09:29 AM   #5
K. Buz:
Thanks.
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
40 Amp 240 V Hot tub into dryer outlet? MVG Electrical 6 04-03-2011 08:00 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Use Dryer Outlet for Woodworking Tools mikewrobel Electrical 7 08-02-2009 12:01 PM
electric dryer - Chord and Outlet question? WILLIAM RIDGE Electrical 2 12-14-2008 10:45 PM
