Relocating Laundry To A Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 06:36 PM   #1
Relocating Laundry to a shed
I am in Ontario and relocating laundry from cottage to a shed which is just outside wall where main 100amp panel is. The total run of new wiring is about 12 feet total.
I need two circuits, 30 amp 220 volt for dryer and normal 15 or 20? amp for washer and a single light with switch.
Is it best to create a subpanel in the shed or just run two circuits from the panel to the shed?
If a subpanel how many amps should I have in main panel breaker and what wire should I use.
I will use conduit for the wire. Can I put two wires in one conduit if I am not using a subpanel.
Ted806 is offline   Reply With Quote
Old 08-29-2011, 07:51 PM   #2
Missouri Bound's Avatar
If you have any intention of using the shed for anything more than a laundry room, install a sub panel. It's more a matter of preference and future use that will make your decision for you. You can put all the wires in one conduit if sized properly. You will need to run ground wires as well. The light can share the washer circuit.
The Following User Says Thank You to Missouri Bound For This Useful Post:
Ted806 (08-29-2011)
Old 08-29-2011, 09:12 PM   #3
Master Electrician
Rewards Points: 3,866
Don't forget the heat. Water in pipes freezes.
brric is online now   Reply With Quote
Old 08-29-2011, 09:29 PM   #4
Yeah.....like things freeze in Canada
Old 08-30-2011, 07:05 AM   #5
Military Mom of 4
Snav's Avatar
I 2nd that: I'd add a sub-panel.
In fact, in my area - it's required for all outside elements like sheds that are not a continuation of the foundation. We have a lot of tornadoes around here - I think that has something to do with this ordinance that's enforced, purely safety.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 08-30-2011, 07:37 AM   #6
Rewards Points: 1,512
Is the shed attached to the house (shared side wall or back wall)?
Not sure whether the code (CEC) requires no more than one feed (hot, hot, neutral, ground) from house to detached structure. In which case you would run perhaps #6 or #8 gauge wires to a subpanel in the shed.
Old 08-30-2011, 10:45 AM   #7
Thanks for all the useful input.
The shed Is not attached to the house so it seems subpanel is the way to go.
My remaining question how many amps to feed to the sub and what wire to use #6 or #8.. I will not be adding future circuits so I have the dryer at 220v 30 amp and a110 v 20 amp for washer and light.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Sinking Shed willise Building & Construction 3 05-04-2011 11:34 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
