Relocating Island - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 07:04 AM   #1
relocating island
moving island 4' and see that pvc thru slab is broken off inches below floor level with about 5" of romex sticking out; i've already made the trough to accept the new wiring and box for splice.
-do i need to jackhammer around the pvc and attach elbow or can i sleeve the armored over it going to the box for splice?
-i was told a 1" metal box is acceptable (has only the push clips) and to run the armored up to it and then silicone around the outside....is this good?
i will have tile installed over it and want to be sure that i'm doing the work correctly...thanks
lantana is offline   Reply With Quote
Old 09-25-2012, 07:46 AM   #2
Resi EC
Rewards Points: 252
You will need access to that junction box.
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
lantana (09-25-2012)
Old 09-25-2012, 01:20 PM   #3
move island
hmmm...if i can't fish as its coming from under the slab and its right in the entrance (first tile) into the kitchen can you give me an idea? I'd hate to have a 2 x 4 silver metal box top visible upon entry into the kitchen....thanks
Old 09-25-2012, 01:31 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Make a larger hole in the slab, you will probably have to go down to dirt. Pull the existing wire back out of the PVC conduit and extend the conduit with an 90 degree elbow to your new location. NM cable (unless it is UF) should not have been installed in that conduit. Replace it with individual THWN wires. Then you can fill the slab with concrete.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 09-25-2012, 01:40 PM   #5
Rewards Points: 150
If it's not in the traffic pattern, you could build a bookcase above the box location, make the bottom part of the bookcase a cabinet with a door (for access to the junction box) and then mount the j-box inside that bottom cabinet.
Dave632 is offline   Reply With Quote
The Following User Says Thank You to Dave632 For This Useful Post:
Old 09-25-2012, 02:34 PM   #6
Licensed electrician
Rewards Points: 1,028
A much better option would be to reroute the conduit and extend it to the new location so no junction box is needed.
Old 09-25-2012, 02:56 PM   #7
Rewards Points: 150
Agreed, but I believe the OP wanted to avoid taking a jackhammer to the slab as much as possible.
Old 09-27-2012, 12:58 AM   #8
Thanks Jim/Dave...
Actually that is exactly what I am trying to avoid as I know that I have tension wires in my slab and don't want to take even the smallest chanced of hitting one.
Have either of you gents used the splices that 3m makes that I read can be used for this scenario?
I'm a newbie now here but have visited this DIY site many times (just not had to post as most questions of mine were already discussed). Thanks for the advise.....regards
Old 09-27-2012, 09:51 PM   #9
Are you sure your slab is post tensioned or is it just mesh or rebar?
HELP - kitchen island receptacle yogaf Electrical 6 02-15-2012 07:56 PM
Island sink drain problem oldphoneman Plumbing 2 02-06-2012 11:56 PM
Kitchen Island walkway inxs Carpentry 3 10-02-2010 08:14 PM
Island help wells1bj Interior Decorating 3 12-01-2009 04:54 PM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 08:37 PM
