Relocating Irrigation Pump Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 01:23 PM   #1
Rewards Points: 248
I want to move my irrigation pump and outlet to higher grounds. I want to move it back about 2 feet and vertical about 2 feet. The river that it pumps from is consistently higher since they started draining a lake. The pump pipe shouldn't be difficult. But the electrical outlet maybe.
The outlet is connected to a post which is cemented in the ground. The the wire runs under ground to my house. I'm assuming the wire is in metal conduit. If I move it back, how do I get rid of the excess conduit without damaging the wires inside?
jburchill is offline   Reply With Quote
Old 06-18-2013, 01:35 PM   #2
joed's Avatar
Rewards Points: 12,440
The proper way is to remove the wires, adjust the conduit and then pull new wires.
You could tie a pull string to the wires. Pull them back far enough to work on the conduit and then use the pull string to pull the wires back.
Old 06-18-2013, 05:20 PM   #3
Rewards Points: 248
I'm not sure if I'll have the option to pull the wires back. The wire runs from house to the pump which is about 75 feet. I am not able to pull from the one side.
Old 06-18-2013, 08:15 PM   #4
Resi EC
Rewards Points: 252
Might, carefully, dig down where the conduit comes up, it may be direct bury wire and sleeved up with conduit.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-18-2013, 11:25 PM   #5
" Euro " electrician
frenchelectrican's Avatar
What type of conductor you have in there like THHN/THWN indivual conductor or UF cable ? that will make the differnce on how we can help you on that and the conduit ( pipe ) itself is PVC or what ??
Merci,
Marc
Old 06-19-2013, 08:20 AM   #6
Rewards Points: 248
hmm, never thought of that. I 'll have to dig it back further. good idea
Need advice on irrigation pump DanDaMan Landscaping & Lawn Care 2 05-08-2012 02:03 PM
Moving irrigation pump? tomberlins Landscaping & Lawn Care 5 04-08-2012 08:26 PM
MasterCraft shallow well pump not happy rtoni Plumbing 7 06-06-2011 11:41 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Irrigation pump relay rdy2go Electrical 2 06-01-2009 09:42 PM
