Relocating Dryer Electrical Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2009, 09:47 AM   #1
Landlord
Rewards Points: 89
Relocating dryer electrical outlet
I'm having to move my eletrical outlet to the next stud. Is there a min distance it has to be from the washer hose connections? Any code violations here??
cocean is offline   Reply With Quote
Old 07-24-2009, 10:15 AM   #2
Rewards Points: 160
No code that I know of but others may know more. It only makes sense to not locate the receptacle anywhere it might get wet if things start dripping or the outlet hose comes loose. It also makes sense to put the receptacle some place where you can get at it w/o having to move any of the appliances.
philS is offline   Reply With Quote
Old 07-24-2009, 10:23 AM   #3
Also keep in mind it is going to need to be GFCI.
Paelectrican is offline   Reply With Quote
Old 07-24-2009, 10:32 AM   #4
Landlord
Rewards Points: 89
How would you GFCI it? Wouldn't already be GFCI'd if it was built in 1992?
Old 07-24-2009, 10:37 AM   #5
Licensed Pro
If it is a 120/240 dryer circuit, it does NOT need to be GFCI protected.
Old 07-24-2009, 10:37 AM   #6
Is it a gas or electric dryer? If it is a gas dryer and only requires 120volts, and is within three feet of a source of water, it does have to be gfci.
Old 07-24-2009, 10:55 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
NEC 210.50 (c) Laundry appliances shall be installed within 6' of the intended receptacle outlet.
NEC 210.8 (7) only 15 or 20 amp 125 volt rated receptacles installed within 6' of a laundry sink are required to have gfci protection.
Technically if you have to add on to the wiring of an existing 3 wire dryer 120/240 (electric not gas) that only has 2 hots and a neutral in the supply you would be in violation of the NEC codes for single family dwellings.
A 4 wire branch circuit with neutral and ground separate is required for all new construction and additions.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 06:01 PM
Installing dryer outlet in laundry room ManMythLegend Electrical 11 07-13-2008 10:36 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
