Relocating Cable Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 03:31 PM   #1
The prior owners of our house drilled a hole in the floor (through the carpet and into the crawlspace) to bring up cable into the office.
I'd like to remove the carpet and tile the office floor. I would need to relocate the cable outlet up to the wall, where they are normally found.
We have good access in the crawl space, but I can't figure out if its possible (or how hard it is) to bring the cable up from the crawlspace and run it through the wall.
Ideas?
Kiwi. is offline   Reply With Quote
Old 02-10-2009, 03:53 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Measure where the hole is in the floor to the wall and add 2" . Get an old work box or low voltage old work box and cut the sheet rock out to allow the installation of the box. Then go under the house and measure over to that measurement. Drill into the wall, pull the old cable out and stick it in your new hole. Hook it up to a cable jack and mount it to the box.
wirenut1110 is offline   Reply With Quote
Old 02-10-2009, 03:54 PM   #3
Contractor
precisionbuild's Avatar
Interior or exterior wall? wirenut has it right.
precisionbuild is offline   Reply With Quote
Old 02-16-2009, 01:15 PM   #4
Its an exterior wall.
I got down into the crawl space this weekend. It looks like I have access to be able to drill a hole that should line up (vertically) with the open space in the wall. So I was planning on drilling a hole and threading the cable up, and putting a box in the wall.
Question - Any tips on threading the cable up through a wall that has insullation in it?
Old 02-16-2009, 01:49 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
You may try using a straightened out coat hanger and taping the wire to the end of that. The stiff metal of the coat hanger helps to poke right through the insulation, and since your going from the floor up to an outlet box probably not higher than 18" this should be a realtively simple task. You may find it easier to have one person pushing the cable up from the crawl space and someone at the hole ready to grab it once they can see it.
theatretch85 is offline   Reply With Quote
Old 02-16-2009, 02:19 PM   #6
This is what we were planning on doing. Thanks.
Old 02-16-2009, 02:28 PM   #7
Can you move it to an interior wall?
Prevents any cold air from coming in
I locate all of my runs on inside walls
Also no insulation to fight your way thru
Old 02-16-2009, 03:44 PM   #8
Had thought about that, but don't really have the access to an interior wall. Plus I've alread put a hole in the wall where I want the cable to go!
Old 02-16-2009, 04:36 PM   #9
Rewards Points: 6,652
I would place a jack on both walls, especially if you plan on rearranging in the future. Also while you are at it, look at Cat-5 & telephone at the same jack. I have 2 runs of Cat-5 at our main entertainment center, and all other runs have one Cat-5 run. At the main entertainment center I also placed an Access Point to allow WiFi use anywhere in our home.
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-19-2008 12:03 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
