Relocating A 200 Amp Service - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 12:22 PM   #1
Relocating a 200 amp service
My current service is setup as follows: Power Co -->Meter and 200A Outdoor thru-lug box --> 25 feet svc cable --> 200Amp interior panel.
My new location for the 200A service is an additional 25 feet away. Would it be ok to put an outdoor thru-lug box under the house to act as a junction box and add another 25 feet of svc cable and ground to the run?
The end result would be Power Co -->Meter and 200A Outdoor thru-lug box --> 25 feet svc cable --> 200A Outdoor thru-lug box --> 25 feet svc cable -->Interior 200A service panel?
I'll keep all cable enclosed in conduit and tied up neatly to the underside of the house.
Any other suggestions? I'm just trying to avoid having to re-dig that 24" deep service trench to the house from the pole if I can.
RBlack is offline   Reply With Quote
Old 05-23-2011, 12:27 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
It does not have to be a feed through panel, just use a pvc junction box.
Make sur the connector you use are rated for the type off wire.
Polaris make great connectors for this.
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 07:55 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
