Reliability Of A Refrigerator Compressor? Need Answers - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 04:24 PM   #1
Question
Reliability of a refrigerator compressor?I Need answers
I am building a modle of a 3 barrelled Vulcan minigun for an airsoft project. I need to know if a refridgerator compressor will put out enough psi to propell an airsoft bb effectively. If you have any answers or suggestions please reply
Mufasa02 is offline   Reply With Quote
Old 08-17-2011, 04:53 PM   #2
Experienced
Jackofall1's Avatar
If this is some kind of terrorist plot I would think we are safe...... after that what the heck is an airsoft bb?
Mark
Old 08-17-2011, 04:54 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,942
Pressure is not the problem. It certainly will produce enough pressure. I seriously doubt the flow rate will be sufficient though. A real 6-barrel Vulcan cannon fires approximately 6000 rounds per minute, or 100 per second. If you want any semblance of realism, you'll need to make your airsoft version fire at least 40-60 per second (800-1200 RPM for your 3-barrel assembly). That requires a LOT of air. CO2 or a high pressure air tank (like 3000PSI air for paintball) would probably be the only feasible option, aside from a fairly large 2-stage compressor.
The air supply is probably the easiest part of this project.
mpoulton is online now   Reply With Quote
Old 08-17-2011, 05:00 PM   #4
Thank you I just need to figure out how to build the air supply with a trigger or button? Any suggestions?
Old 08-17-2011, 05:04 PM   #5
Btw way an airsoft bb is a platistic sphere shot out of a a gun similar to a paint ball gun, they are harmless, basically non-lethal bb guns
Old 08-17-2011, 05:17 PM   #6
Household Handyman
Rewards Points: 1,408
I think I follow what you are doing here, so: Would a tank of compressed nitrogen do the job?
Old 08-17-2011, 05:20 PM   #7
Well is a tank of compressed nitrogen expensive? Because I'm trying to keep the price as low as I can. and how would I get my hands on compressed nitrogen
Roofing -Looking for some Answers frythedevil Roofing/Siding 2 07-07-2011 08:48 AM
New House, new problems. need Wall Answers MerrittHII Building & Construction 0 03-06-2011 08:55 PM
Havc ? need fast answers chris0914 HVAC 8 08-22-2009 07:51 AM
Answers have eluded me...Please Help Tinkerbell Roofing/Siding 5 06-25-2009 09:04 PM
Finally got some answers, need some advice 737Pilot Building & Construction 9 04-19-2008 12:55 PM
