Old 12-18-2011, 12:47 PM   #1
Relays as they relate to NEC standards
To those of you that know the NEC code better than I, I have a few specific questions.
My installation pertains to 2005 NEC, but I suppose following the standard of the newer(2008) or newest(2011) wouldn't hurt either.
I'm wanting to use a low voltage(24vac or 12vdc) switch to control a 120VAC load via a relay.
NEC 725.136 (D) (1) mentions 1/4" separation.
  1. "blade" style relays - Pretty sure this is a big NO.
  2. RIB2421B, which also has a nice range of options(Low voltage AC/DC coil, 120VAC coil, 277V coil with NO and NC contacts)
  3. The seemingly popular Amprobe rc 120s. This completely eliminates the low-volt and high-volt wiring occupying the same box. They are a bit pricey and the cost adds up quickly.
Examples of all 3:
  1. http://www.amazon.com/Dayton-1EHR8-R...4230282&sr=8-5
  2. https://www.hvacusa.com/store/power-...21b-p-90090425
  3. http://www.amazon.com/Amprobe-RC-120.../dp/B0029XOKH0
Would #2 fall under NEC?
Any article references would be appreciated!
fuzzball03 is offline   Reply With Quote
Old 12-18-2011, 01:25 PM   #2
Found a few others that shouldnt be an issue:
http://functionaldevices.com/pdf/dat...CLC212-D15.pdf
http://functionaldevices.com/pdf/datasheets/CLC212.pdf
http://functionaldevices.com/pdf/dat...106_SERIES.pdf
Old 12-18-2011, 02:35 PM   #3
For vehicles they are called "solenoids" and are designed to be mounted on a firewall or plugged into a fuse box.
In electronics they are called "relays" and are designed to be mounted on a printed circuit board and soldered.
In the "electrical world", they are called "contactors" and are designed to be mounted in an electrical box and have screw terminals to connect wires.
Search for the word: contactor
Billy_Bob is offline   Reply With Quote
Old 12-18-2011, 05:59 PM   #4
I=E/R
a7ecorsair's Avatar
The NEC doesn't "regulate" relays. If the relay is listed for the application by the manufacture then you can use it.
a7ecorsair is offline   Reply With Quote
Old 12-18-2011, 08:49 PM   #5
Okay, thanks. That answers my main question.
the CLC212 seems to be the perfect application, plus it's an average of $15 cheaper than the amp-robe AND it's available in a NC configuration so I can use the more common configuration of magnetic door sensors
Can I connect 3 relays to one, 12 volt ac adapter? tibberous Electrical 25 07-27-2011 10:31 PM
Professional standards nothandy1 Flooring 7 06-15-2011 08:02 AM
Thermostat with separate fan and heat relays Steve-P HVAC 9 11-12-2010 05:46 AM
Low Voltage Relays jlatulippe Electrical 8 11-28-2009 01:01 AM
NFPA Standards Southengineer Electrical 6 09-09-2009 09:43 AM
