Relays - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2008, 02:19 PM   #1
Relays
In what state are the contacts of a relay in, when de-energized, if they are nc. Do they open upon energizing or the opposite?
Steven Jackson is offline   Reply With Quote
Old 08-10-2008, 04:04 PM   #2
Rewards Points: 506
Send a message via AIM to theatretch85
When a relay is de-energized, the contacts that should be connected are the NC or Normally Closed contacts. When you energize the relay coil, the NC contacts open up and switch the NO (normally open) contacts closed.
theatretch85 is offline   Reply With Quote
Old 08-10-2008, 04:12 PM   #3
Electrician
If they are normally closed, then they are normally closed. apply power to the coil and they are no longer closed.
chris75 is offline   Reply With Quote
Old 08-10-2008, 06:11 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
A little diagram to help with what has already been said.
