Relay Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 04:17 PM   #1
Relay Questions
I have a relay that I bought at Radioshack and was told I could use this relay in place of this relay. The end goal is my Christmas lights "dancing to music. Will this work and if so please explain. Thanks this is my first time using relays.
What I should Have- http://www.newark.com/crydom/d2w203f...-3a/dp/79K4343
What I do have- PC Relay 12VDC Rated 10A at 120VAC/24VDC If you need more about this just ask it has more info on the back.
The Goal http://www.tinkernut.com/archives/27
Basscasper is offline   Reply With Quote
Old 12-12-2011, 04:38 PM   #2
Your relay is a bit better than recommended. Your relay can handle 10 amps instead of the videos 3.5 amps. One question I have, is your relay you purchased solid state? It's important to the longevity of the system. An standard solenoid relay wont last nearly as long.
Holy Funk is offline   Reply With Quote
Old 12-12-2011, 05:15 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,096
Also ? What is providing the switching current ?
Cause the relay will require more current to operate then the
the solid state switch.
And if the switching is rapid and frequent,
the relay will not last as long as,
a solid state switch.
But if it is slow it will be ok !
dmxtothemax is offline   Reply With Quote
Old 12-12-2011, 05:18 PM   #4
Here is a Picture
The relay also has 5 pins on it as well
Old 12-12-2011, 05:22 PM   #5
Your relay has a normally open and normally closed contacts. You would want to use the normally open leg so the contact closes as the speaker sends current through your coil. I think your on the right track.
Old 12-12-2011, 06:07 PM   #6
speaker power
I just realized that my speakers that i have dont plug into the wall just the device. will that matter?
Old 12-12-2011, 06:23 PM   #7
As long as the signal from your pc, iPod, whatever, is strong enough to switch the coil it should be fine. I feel pretty confident it will. Amplified speakers need to be plugged in. You're just looking for a signal current, not the noise itself.
Old 12-12-2011, 07:09 PM   #8
I think I came SO close...
Some thing went wrong and I heard a POP and then a small electric flame and then the relay melted.
Old 12-12-2011, 07:38 PM   #9
Quite hard to say from here, but I'd guess a dead short as soon as you plugged in the 120v. Was everything isolated/insulated? Even the unused contact?
Old 12-12-2011, 09:50 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 806
What voltage are you using to activate the relay?
The coil is 12Vdc....if you used 120Vac....no wonder it melted....
ddawg16 is online now   Reply With Quote
Old 12-13-2011, 08:55 PM   #11
Double check all connections to the relay !
You must have a wiring error somewhere,
Theres not much that can go wrong in a relay,
Except putting 120 on the coils,
That would certainly cause destruction and flames.
Old 12-13-2011, 09:28 PM   #12
Missouri Bound's Avatar
..sounds like a 4th of July display....
Old 12-13-2011, 11:04 PM   #13
Click on the "data sheet" for the recommended solid state relay and you get this page...
http://www.crydom.com/en/Products/Catalog/d_2w.pdf
On that page for the "input" which would be the same as the "relay coil" you have on the mechanical relay, note the values are MUCH different!
Control Voltage Range 3-32 VDC
Must Turn On Voltage 3.0 VDC
Must Turn Off Voltage 1.0 VDC
Typical Input Current @ 5 VDC 3.0 mAdc
Nominal Input Impedance 1500 Ohm
Note input on the above is 1500 Ohms and on the mechanical relay 400 ohms!
And to drive it, 3 mA as opposed to 30 mA on the mechanical relay!
I recommend you get the specified part.
Billy_Bob is offline   Reply With Quote
Old 12-14-2011, 04:35 AM   #14
If he is attempting to drive the relay from the speaker lines
of an amplifier, it wont matter too much weather it is
400 or 1500 ohms.
But considering the results of his first attempt
then I would say leave well enough alone,
Leave it to a pro !
Or at least get an electricain to check it,
before he attempts to power it up again !
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 07:52 PM
Electric Baseboard Heat - relay problem? sporkman HVAC 7 11-21-2010 07:43 PM
Relay, 24 volt to 110 Captflx Electrical 7 12-09-2009 09:45 PM
Heating relay wiring Toledo Electrical 6 11-26-2009 01:03 PM
newbie...relay problems jfabes Electrical 11 05-06-2008 05:48 PM
