Relay To Power A Microwave - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 03:19 PM   #1
Relay to power a microwave
I'd like to use a relay to power an 800 watt microwave. Would this relay be sufficient?
http://ribrelays.com/images/product/...s/RIB01BDC.pdf
arib2 is offline   Reply With Quote
Old 01-07-2013, 03:22 PM   #2
Rewards Points: 744
Your link is invalid.
Seattle2k is offline   Reply With Quote
Old 01-07-2013, 03:25 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,902
Yes, it will handle the load. But why? Microwaves are not intended to be frequently powered on and off. The clock will reset every time, and I can't imagine what benefit would result from it.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-07-2013, 03:30 PM   #4
We want to control access. People will swipe their access card and the system will close the dry contacts on the relay for a set period of time.
if you cant see the pdf, try accessing thru here: http://ribrelays.com/Products/Dry-Co.../RIB01BDC.html and see the datasheet
RIBU1C Relay in Residential theatretch85 Electrical 6 11-13-2012 11:48 AM
110v Volt power sensing/switching relay cbechdel Electrical 0 11-08-2012 01:48 PM
Electrical Relay for Evaporative Cooler Power highdesert Electrical 10 07-06-2010 10:49 AM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
