Relay - I Think ?? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 11:17 AM   #1
Relay - I think ??
This may be the wrong forum as it is an electrical question associated with HVAC, but here goes anyway.
I need to add an accessory to my HVAC furnace. The electrical panel allows for addition of accessories wired to the panel so that they are enganged when the system is. The problem is that when I look at the specs on the panel, no accessory can draw more than one amp. This accessory draws 1.67 amp (at 110VAC). Can I get appropriate power elsewhere and install an inexpensive relay that accepts the 110v source from the HVAC panel to trip a relay that allows the flow of 110v from another source to power the accessory?
If so what device is recommended and where can I get it?
Thanks in advance
DIY_SRG is offline   Reply With Quote
Old 01-18-2009, 11:36 AM   #2
Electrician
ctsmiths's Avatar
Rewards Points: 150
Relay is the way to go, you need to go to a electricial supply, possibly a HVAC supply( dont know if they have relays like that) just tell them you need relay that uses a 110 v ac coil and is rated for at least 5 amps on the contacts. They should be able to get you what you need.
ctsmiths is offline   Reply With Quote
Old 01-18-2009, 01:18 PM   #3
Electrician
I like these myself...
http://www.functionaldevices.com/pdf/RIBU1C.pdf
chris75 is offline   Reply With Quote
Old 01-18-2009, 01:57 PM   #4
Electrician
ctsmiths's Avatar
Rewards Points: 150
Thats a good one. I dont run into to many residential relays, I deal with industrial stuff mostly, but I have to remember this one cuz im sure Ill need one at some point.
Old 01-18-2009, 04:47 PM   #5
Relay
Thanks to all that replied - I will heed the great advice
relay advice doorman HVAC 1 11-17-2008 06:23 PM
newbie...relay problems jfabes Electrical 11 05-06-2008 04:48 PM
Gas Valve Relay? OCDC HVAC 3 01-21-2008 07:37 AM
