Is Regular Wire Ok To Use If Fishing Through Existing Walls? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2008, 10:08 PM   #1
Is regular wire ok to use if fishing through existing walls?
I want to add another light in my kitchen. Is it ok to use the usual 12/2 or 14/2 wire to fish through existing walls or do I need to use wire that is encased in metal to protect it?(since it will be loose in wall cavity) Also, I hope to add the light to an existing circuit. As long as a map the circuit and calculate its current load and the additional light fixture wont increase the load too much, I should be ok? Is this the usual approach?
slatergrl is offline   Reply With Quote
Old 01-31-2008, 10:12 PM   #2
Ottawa, Canada
Regular 14/2 is fine. The shielded cable is for exposed locations - which means out in the open where you can see it. You have to protect it when passing in front of a stud (with a metal plate) so the next tenant doesn't put a nail through it. This is all for Ontario code but I think this is fairly standard across Canada and US
Snailspace is offline   Reply With Quote
Old 01-31-2008, 10:22 PM   #3
Learning by Doing
Leah Frances's Avatar
Get yourself some fish tape and some decent drill bits. I have been trying to run wires from the 1st floor to the basement for three days. Long story. Prepare for the unexpected and as much as possible KISS.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-31-2008, 10:32 PM   #4
Ottawa, Canada
Oh - and the load question - a light doesn't add much. Don't add it to one of the split circuits (anything you plug a toaster / kettle into) it's not code and your light will dim every time you brew. If you're adding a second light to an existing one, then take off that. If it's a new light on it's own new switch, take it off an existing light at the switch or the light (whichever has the line to the breaker) or off a regular circuit nearby - a wall receptacle in an adjacent room maybe.
Old 01-31-2008, 10:35 PM   #5
Unless you are in Chicago you can use "regular" wire (NM )(Romex).
Use the same size as the circuit you are tapping into. An additional light or two won't over load the circuit. Some places use 12, some 14.
Make your connections TIGHT.
Loose connections cause arcing/sparking/heat/smoke/fire/death. Use junctions boxes.
220/221 is offline   Reply With Quote
Old 02-01-2008, 06:03 AM   #6
WOW, all these responses were so helpful and cleared up alot of the "gaps" of info that weren't clear in my little do it yourselfer wiring book. Thanks alot. One last ?, what are junction boxes?
Old 02-01-2008, 08:13 AM   #7
Rewards Points: 1,452
You can use the term junction box if there is no switch or receptacle there, just wires that come together to be connected. The same kind of box can be used, just be careful of the number of conductors (wire ends) coming in and the size of the box.
Junction boxes with exposed covers are required for in-wall (concealed) wiring; you may not have connections or joints or splices loose inside the wall.
Old 02-04-2008, 08:16 PM   #8
Thanks for the help
Old 02-04-2008, 09:51 PM   #9
Electrician philosopher
220 You rock.....
Andy in ATL is offline   Reply With Quote
Old 02-04-2008, 09:53 PM   #10
Dont say "grl" unless you want to get hit on on this site...
Andy
We don't help girls on this site................
Old 02-29-2008, 04:47 PM   #11
ANDY! Then explain to me why "hooter's" thread has 200+ replies & 1400+ views?
stan 41943 is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Bonding (bond wire) & Spa Installation on existing concrete pad crusius2 Electrical 1 11-14-2007 01:00 PM
Raising existing walls of a garage ok2rvtravel Remodeling 3 10-09-2007 12:45 PM
Blending into existing walls J187 Painting 5 07-06-2006 11:26 AM
