Regular Switch To Dimmer Switch But Different Colored Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 11:41 PM   #1
Regular switch to dimmer switch but different colored wires
Regular switch has red, white and black wire coming from inside the switching unit but new dimmer has 2 black and one green from inside the switch, How do I connect these??
dr-gregg is offline   Reply With Quote
Old 08-07-2012, 11:46 PM   #2
"So I Re-Wired It"
MisterZ's Avatar
were only the red and black wires connected to the old switch?? and the white nutted and not connected to the switch??
or did the switch you removed have all three wires attached to it??
the new dimmer switch uses two Black wires (one HOT leg and the other Switched leg)
the green wire is your Ground.
Another question.... is the switch box Metal or non-metallic??
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 07:40 PM
Dimmer Switch Vandiyan Electrical 21 12-15-2008 07:23 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
