Regarding Step Up Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 09:06 AM   #1
Post
regarding step up transformer
Greetings all,
ima newb that was thinking one night, what if i bought a 15000 watt stepup transformer and installed it by a new electrical mains box, that way i wouldnt have any back feed to the grid, and then hooked all my heavy equip to it to save money on utility bill, what do you guys think? http://www.110to240.com/details.asp?ProdID=1006
thanx
DShdw is offline   Reply With Quote
Old 09-22-2012, 09:18 AM   #2
Rewards Points: 1,294
when you mentioned backfeeding I assume you are thinking of powering this with a generator. I think you may need to do some research on Ohms Law to understand what you are tring to do and why it wont do what you think it will.
danpik is offline   Reply With Quote
Old 09-22-2012, 09:31 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What are you powering this with? Gen-set, solar, wind, hydro, couple of hamsters on a wheel?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
DShdw (09-22-2012)
Old 09-22-2012, 12:27 PM   #4
Oso954's Avatar
Rewards Points: 1,020
You are talking about a step up transformer, yet you posted a link to a step-down transformer.
You might also want to learn the difference between single phase and split phase power.
It's not going to do what you think it will.
Oso954 is online now   Reply With Quote
Old 09-22-2012, 02:31 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,922
Whatever you're trying to accomplish, that won't do it. We need a lot more information to be able to help, though. Also, that transformer is definitely not really good for 15kW. It's nowhere near big enough to be a 15KVA transformer. Probably more like 5 at the most.
mpoulton is online now   Reply With Quote
Old 09-22-2012, 08:32 PM   #6
no had i not stated about not backfeeding to grid, i would have a bunch of ppl msg me that it can kill workers is why i added that statement, i'm just gonna hook up energy eating stuff like ac. so do you have any clues if this is worth doing? or u just gonna continue as u have, with no helpful info ty
Old 09-22-2012, 08:35 PM   #7
actually that page had em listed as stepup and stepdown so oh well
Old 09-22-2012, 08:36 PM   #8
ok so no helpful info thanx anyway
Old 09-22-2012, 08:47 PM   #9
Master Electrician
Everything is relative. So you have a light that runs on 240v and 120v. For arguements sake we'll say Its a 100w bulb. That bulb draws 1.2a at 120v and .6a at 240v useing simple ohms law. Using the same ohms law, as we already know, it draws 100w. Therefore costs the same amount of money to run on either voltage. Actually it costs more due to the ir squared losses in the transformer. The only upside is smaller wre sizes and that only works if the equipment is rated for said voltage. If not then your equipment goes boom.
There's your answer. The previous its pointless answers are spot on.
I don't however have a clue what you talking about when you say your backfeeding your grid, please enlighten me.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
jbfan (09-22-2012)
Old 09-22-2012, 09:10 PM   #10
Rewards Points: 1,192
See what I DM?
bobelectric is offline   Reply With Quote
Old 09-23-2012, 12:15 AM   #11
dmxtothemax's Avatar
Rewards Points: 5,188
Originally Posted by DShdw View Post
Greetings all,
thanx
Sorry to bust your bubble sir !
BUT transformers do work forwards or backwards.
So yes it can still backfeed.
dmxtothemax is online now   Reply With Quote
Old 09-23-2012, 12:39 AM   #12
Oso954's Avatar
Funny, when I follow your link, the only transformer shown is
"15000 WATT TC-15000A TRANSFORMER STEP DOWN CE APPROVED AND CERTIFIED. " "Converts 220/240 Volts down to 110/120 Volts"
near the top of the page the location on the site is shown as
" SamStores: > Voltage Transformers > Step Down-Only for Overseas use-Type 1 "
Yes, elsewhere on the site they sell others, but that is not where your original link took me.
Old 09-23-2012, 04:51 AM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 1,456
Guys...ignore him....he is looking for perpetual motion schemes.....has no idea what he is doing.....or is a troll...
ddawg16 is online now   Reply With Quote
Low Voltage Transformer Problem dlp710 Electrical 2 07-06-2012 09:56 AM
How do Transformers Connect / Cause of outages (transformer fire) jamiedolan Electrical 23 11-30-2011 05:22 AM
Help with a Step Up Transformer TheConsumer Electrical 10 11-11-2011 12:44 AM
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 11:37 AM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
