Old 11-30-2012, 04:11 PM   #1
hohadcr's Avatar
refurbish 60A fuse holder
I have a fuse box with 2x60A fuses. One of the fuses blew often.
i learned that the burn mark on the fuse holder may cause it to burn again easily. There was burn mark on it.
Since I can't find a replacement holder, is there a way for me to refurbish the burned fuse holder? sand it? soak it in vinegar...?
hohadcr is offline   Reply With Quote
Old 11-30-2012, 05:11 PM   #2
Cleaning up the metal to improve electrical contact is possable !
But it is not just about the cleanlyness of the metal,
Its also about the tension of the metal,
overtime and due maily to heat,
the metal losses it tension and wont hold the fuse tightly.
So if it is clean and tight you could try it,
and see how it holds up.
But most people prefer NOT to take chances like that.
dmxtothemax is offline   Reply With Quote
Old 11-30-2012, 06:29 PM   #3
Electrical Contractor
kbsparky's Avatar
Such a fuse holder clamp is worn out. It won't "repair" and has lost its ability to hold a fuse tight.
Best thing to do here is replace the whole box with a decent breaker panel.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
joecaption (11-30-2012)
Old 12-01-2012, 12:53 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Hohadcr.,
I know you may not like to hear this answer here but once that fuse holder got overheated few time it will loose it holding format and the only way you can slove it is replace with modern panel with breakers.
That will take care the issue with it.
Merci,
Marc
Old 12-01-2012, 10:16 AM   #5
As simple box like this would work.
http://www.bing.com/images/search?q=...8D7E1&first=74
Old 12-01-2012, 10:24 AM   #6
Licensed electrician
A new fused disconnect is probably less than $20.
Fuse for chandelier with 12-volt transformer? S_Jeff Electrical 1 08-16-2012 12:19 AM
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 05:22 PM
Furnace fuse holder jimmy21 Electrical 14 12-25-2010 09:05 AM
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 02:36 AM
fuse went BANG davej Electrical 1 01-23-2006 01:37 PM
