Refrigerator In Garage Power - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 12:34 PM   #1
refrigerator in garage power
We just purchased a refrigerator for our garage.
Our current configuration is this:
  • 20A circuit in garage
  • 15A GFCI receptacle near fridge
  • Home alarm system plugged into bottom of GFCI receptacle
With the alarm system plugged in, there is not enough space to plug in the refrigerator power cord.
So my question is this: Given the current setup, can I mount a surge protector/power strip to the wall, plug that into top of the GFCI, then plug the fridge into that? Or, would it be better to plug the fridge and power strip into the GFCI, then the alarm system into the power strip?
I'm mainly worried about the refrigerator...
bodekms is offline   Reply With Quote
Old 06-13-2011, 12:58 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
They make a short cord to plug the alarm system transformer into so it does not block both sides of the receptacle.
Here is one: http://www.proacousticsusa.com/produ....php?pId=10565
But buy it a Walmart, they sell a 3 pack of them for about $5, in the electrical extension cord area.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
ron54 (02-26-2012)
Old 06-13-2011, 07:00 PM   #3
Electrical Contractor
kbsparky's Avatar
Do NOT plug in a surge-protected power strip into any GFCI protected outlet, unless you want nuisance tripping of the GFCI.
If you want to use a power strip, be sure to use a non-surge unit.
-KB
Old 06-14-2011, 04:39 AM   #4
Rewards Points: 1,192
Should be an easy fix to change the receptacle to a 2 gang using an Arlington 2 box.
bobelectric is offline   Reply With Quote
Old 06-14-2011, 07:58 AM   #5
From everything I've read, you're not supposed to plug a refrigerator into a GFCI outlet, but only GFCI outlets are allowed in a garage. Is this right?
Old 06-14-2011, 08:09 AM   #6
Licensed electrician
Rewards Points: 1,294
Refrigerators should be fine on a GFI. There used to be an exception that allowed single receptacles behind appliances to be non-GFI. It has been removed and all garage receptacles now require GFI protection.
Old 06-14-2011, 04:17 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,904
Only a faulty refrigerator will trip a GFCI. It just so happens that many older refrigerators do have moderate ground current leakage, and will do so. This is not a problem with the GFCI, or a good reason to avoid plugging a fridge into a GFCI - it's a good reason to get a new fridge or repair the problem.
Of course, the reason people are concerned about having a fridge on a GFCI is that if it does trip, you may not realize it until the fridge warms up and the food is spoiled. This guy will also have his alarm system plugged into the same GFCI, and it surely has an AC power failure alarm that will go off if the GFCI trips. Problem solved.
mpoulton is offline   Reply With Quote
Old 06-14-2011, 08:59 PM   #8
kbsparky's Avatar
Originally Posted by mpoulton View Post
Only a faulty refrigerator will trip a GFCI......
Not so. Lightning storms and power surges can trip out GFCI's quite handily.
Even with nothing plugged into `em.
I don't believe that the CMP's took that into consideration when they mandated the GFCIs in critical locations.
-KB
Tags
garage , power strip , refrigerator
Wiring power to detached garage, more questions WillK Electrical 17 04-24-2011 01:48 AM
Wind Turbine for Garage Power? jpearson311 Electrical 4 04-12-2011 04:08 PM
power to my garage toddman0 Electrical 3 11-27-2010 11:10 PM
garage door opener power handifoot Electrical 4 11-23-2008 08:30 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 03:51 PM
