Refridgerator - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 03:59 PM   #1
Question
Refridgerator
I have a 6 year old Kitchenaid KBRA20E Refridgerator/Freezer. My temperature control is set on 4 which is in Bold because I assume it is the recommended setting for the fridge. 7 is the coldest. My water dispenser, which is located inside the fridge, is frozen and the stuff in the crisper is freezing. Occasionally, the milk on the top shelf freezes too. I just turned the control down to 3 and I will see tomorrow if that helps but ve always had it at 4 and this just started happening. Any tips on what I should look at first?
Tahoe Dave is offline   Reply With Quote
Old 01-21-2012, 04:04 PM   #2
Licensed electrician
Rewards Points: 1,264
Clean the coils of the collected dust bunnies. Pull the grill under the doors.
Old 01-28-2012, 07:22 PM   #3
Thanks for the advice.
Old 01-28-2012, 07:22 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Wow that was rough!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-28-2012, 07:34 PM   #5
Originally Posted by plummen View Post
Wow that was rough!
Sorry Plummen. My comment was to Julius793 and not directed at you. I just have a low tolerance for jacka_ _ _s who anonymously post antagonistic comments to other people for their own amusement.
Old 01-28-2012, 08:40 PM   #6
Rewards Points: 1,192
Evaporator fan running?
bobelectric is offline   Reply With Quote
Old 01-28-2012, 10:11 PM   #7
Missouri Bound's Avatar
RE: the coil cleaning....there is a long brush made just for this purpose...resembles a thick pipe cleaner with a handle, about 24-30 inches long.
Old 01-29-2012, 12:11 AM   #8
Julius793's Avatar
Which part is anonymous? And what di you say I missed it, you can pm me.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Tags
compressor , freezing , refridgerator , thermostat
sears side by side refridgerator not cooling - freezer working dkusko Appliances 0 09-05-2010 12:22 PM
Refridgerator broke down The Ferret Appliances 3 01-07-2010 12:45 PM
Engineered wood failed under refridgerator BlueBSH Flooring 15 11-20-2009 12:13 PM
refridgerator stopped cooling mikeviggy Appliances 2 06-24-2009 01:20 AM
Refridgerator door seals mt232 Appliances 2 03-12-2008 01:23 PM
