Refridgerater On GFCI Circuit?, Continuing Debate - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-29-2013, 09:40 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by gregzoll View Post
When are you going to realize that you tend to start petty arguments that are pointless, and have nothing to do with the topic at and. I have already pointed out, that in a commercial situation, or even residential, cords will be torn up and unsafe, before the ground pin comes up missing on it. End of discussion.
Is this just your opinion or fact? lol….
Old 10-29-2013, 09:40 PM   #17
Rewards Points: 6,652
Originally Posted by stickboy1375 View Post
When do you realize you are only right after someone corrects your incorrectness? good night greg. oh, and go back and reread the thread and see what you wrote vs what I wrote.. I win, again….
I know when to stop, and when not to be petty. Seems that you tend to do both and do not know when you have turned the tables on your own self.
Suggest you understand better Stickboy, when it is time to just stop instead of continuing to be controlling in these discussions as you tend to do, while being too petty about stuff.
BTW, you won nothing. You just made yourself sound like a Teenage girl with that last statement.
Old 10-29-2013, 09:42 PM   #18
E2 Electrician
But it still bothered you… Thats how I won…
Old 10-29-2013, 09:49 PM   #19
Rewards Points: 150
but it still bothered you… thats how i won…
are you serious? How old are we, 2?
romex1220 is offline   Reply With Quote
The Following User Says Thank You to romex1220 For This Useful Post:
gregzoll (10-29-2013)
Old 10-29-2013, 09:50 PM   #20
E2 Electrician
Oh yeah, it seriously bothers Greg… and it's a forum, who really judges people on here? lol…
This is FREE information, so lets keep it legit and informative, and not give out false information…
Old 10-29-2013, 10:31 PM   #21
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
How did we ever survive before gfis/afcis/in use covers/tamper resistant outlets.......?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Kyle_in_rure (10-30-2013)
Old 10-29-2013, 10:58 PM   #22
Wrong again. Like Romex stated, what are you 2? You always are petty about stuff, and never know when to stop, do you?
Old 10-29-2013, 11:01 PM   #23
Like most of us still do. Even worse is that if you do not make your kid wear a helmet when skateboarding, bike riding, keep them out of trees or off of the top of boulders, you are a bad parent.
I remember riding down the hill in the woods back behind my house growing up, and try not to hit the trees on either side. We also had a terrace behind my cousins parents house, and would start at the top, ride down to the terrace between their property and the field at the bottom, with one of us either on the handle bars, or between the seat and the handle bars.
Got scratched up, dusted ourselves off, and did it all over again.
The Following User Says Thank You to gregzoll For This Useful Post:
plummen (10-30-2013)
Old 10-29-2013, 11:03 PM   #24
Originally Posted by curiousB View Post
Gfcis don't trip due to power factor of the load. They trip because the current in the hot and neutral do not cancel out in the differential transformer of the GFCI. If the load is highly inductive the currents will still cancel out with no ground fault. Once a ground fault exists the current are no longer equal and the GFCI trips.
Urban myth that inductive loads are problems for GFCIs.
Not an Urban Myth. It was because when they first came out, motorized loads or things like refrigerators would trip them, when gfci's first were introduced. Why do you think that dryers and wash machines are still not required to have GFCI breakers on them, same as hvac equipment.
Sooner or later, those four will be required to have GFCI protection.
Old 10-29-2013, 11:43 PM   #25
Lord of Slums
Rewards Points: 1,974
two questions. Will a gfci work in a home that has no ground? I was told a ground wire is useless, it is only for lightning strikes, is there any truth in that.
mj12 is offline   Reply With Quote
Old 10-30-2013, 12:06 AM   #26
Yes. As for the ground wire for lightning strikes, that in itself is a whole lot of misinformation right there. In older Single Phase systems, the ground wire is used as a return path back to the distribution system. You would have a wire from the system at the pole, attached to a rod in the ground, then at the house, you have the same thing. As long as you have the right resistance, you have a good return path back, so that you are able to complete the circuit, so your lights are on at the house. Now if you lost your ground, bad things would happen, such as fires, blown fuses, electrical shocks.
Now the ground wire is used as a safety measure in how today's systems are wired, but still actually serves the same purpose that it did before, in the old Single Phase system.
Old 10-30-2013, 06:39 AM   #27
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
Yes, in fact they are sometimes used to install a 3-prong receptacle in a two-wire wired home.
You are confusing and equipment ground (the wire run with the circuit wires inside a home) with a grounding electrode conductor (the wire going to the ground rod outside). They are two very different things, with almost no relation to each other, yet are both "grounds".
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
Jim Port (10-31-2013), mpoulton (10-31-2013), plummen (10-30-2013)
Old 10-30-2013, 07:02 AM   #28
E2 Electrician
Wrong again Greg, older appliances would trip GFCI's only because they were in fact leaking current, UL has far stricter requirements on appliances and allowable current leakage… Think about this, if an older appliance is tripping a GFCI at 5ma, how safe do you really think those appliances were?????
Washer do not require GFCI protection because they are not considered a portable appliance, lowering the chances that the ground pin will be intact, and dryers are above 20 amps, again, not going to be continually plugged and unplugged.
Old 10-30-2013, 07:05 AM   #29
E2 Electrician
it's all about lowering the chances of an accidental death, everything evolves as people are more educated in safety… look at how the automobile industry has changed for a better survival rate in a crash.
Old 10-30-2013, 07:15 AM   #30
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
Earthing/Grounding for a house or any structure is almost black magic to some people.....
Here are some good references...
http://en.wikipedia.org/wiki/Ground_(electricity)
Equipment earthing conductors provide an electrical connection between non-current-carrying metallic parts of equipment and the earth. The reason for doing this according to the U.S. National Electrical Code (NEC), is to limit the voltage imposed by lightning, line surges, and contact with higher voltage lines. The equipment earthing conductor is usually also used as the equipment bonding conductor (see below).
Equipment bonding conductors provide a low impedance path between non-current-carrying metallic parts of equipment and one of the conductors of that electrical system's source, so that if a part becomes energized for any reason, such as a frayed or damaged conductor, a short circuit will occur and operate a circuit breaker or fuse to disconnect the faulted circuit. Note that the earth itself has no role in this fault-clearing process[3] since current must return to its source, not the earth as is sometimes believed[citation needed] (see Kirchhoff's circuit laws). By bonding (interconnecting) all exposed non-current carrying metal objects together, they should remain near the same potential thus reducing the chance of a shock. This is especially important in bathrooms where one may be in contact with several different metallic systems such as supply and drain pipes and appliance frames. The equipment bonding conductor is usually also used as the equipment earthing conductor (see above).
A grounding electrode conductor connects one leg of an electrical system to one or more earth electrodes. This is called "system grounding" and most systems are required to be grounded. The U.S. NEC and the UK's BS 7671 list systems that are required to be grounded. The grounding electrode conductor is connected to the leg of the electrical system that is the "neutral wire". The grounding electrode conductor is also usually bonded to pipework and structural steel in larger structures. According to the NEC, the purpose of earthing an electrical system is to limit the voltage to earth imposed by lightning events and contact with higher voltage lines, and also to stabilize the voltage to earth during normal operation. In the past, water supply pipes were often used as ground electrodes, but this was banned where plastic pipes are popular. This type of ground applies to radio antennas and to lightning protection systems.
Permanently installed electrical equipment usually also has permanently connected grounding conductors. Portable electrical devices with metal cases may have them connected to earth ground by a pin in the interconnecting plug (see Domestic AC power plugs and sockets). The size of power ground conductors is usually regulated by local or national wiring regulations.
http://www.ecmag.com/section/codes-s...ctors-building
http://ecmweb.com/bonding-amp-ground...ode-conductors
We have been using electricity for over 100 years....and we are still learning how to properly use it....
Consider the Ufer ground.....discovered during WWII....only now being put into mainstream use.
The Following User Says Thank You to ddawg16 For This Useful Post:
gregzoll (10-30-2013)
spa gfci circuit trips with no load connected jima512 Electrical 15 04-09-2013 12:10 AM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 11:43 AM
Stairway light powered from GFCI circuit? jeh179 Electrical 10 03-23-2011 09:57 AM
GFCI Outlet on 20A garage circuit campos202 Electrical 2 09-10-2009 10:38 AM
GFCI Trips campbellpt Electrical 28 11-21-2008 04:06 PM
