Refridge- Amps? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 09:48 AM   #1
Refridge- amps?
About how many amps does a standard fridge draw?
Sent from DJ's iPhone
Djennis20 is offline   Reply With Quote
Old 10-01-2011, 10:01 AM   #2
Licensed electrician
Rewards Points: 1,758
You can find the info on the dataplate on your fridge. 6-8 amps would be common, although startup amps will be more.
Old 10-01-2011, 10:18 AM   #3
Ok, thanks. Just wanted to make sure I could put my microwave and fridge on same 15amp circuit.
Old 10-01-2011, 10:28 AM   #4
Read the instructions with the MW. it may require its own circuit. If over the range it will.
Old 10-01-2011, 02:42 PM   #5
bubbler's Avatar
Rewards Points: 256
I wouldn't do it... you're going to end up tripping the breaker on a regular basis...
700-1000W for a microwave...
600-900W for a fridge... double that when it's starting, even more if you've got he door open and the little bulb is on
bubbler is offline   Reply With Quote
Old 10-01-2011, 04:05 PM   #6
Code05's Avatar
Rewards Points: 1,104
Assuming both appliances are running correctly, I doubt that even a 15 amp breaker would ever trip even once.
Code05 is offline   Reply With Quote
Old 10-01-2011, 04:21 PM   #7
bubbler's Avatar
Rewards Points: 256
So if you're running the microwave when the fridge starts you don't think that will trip the breaker?
My grandmother had a microwave and fridge on the same circuit, she always had to buy the smaller microwaves (700W), we had to use the "slow blow" fuses in the fuse panel otherwise they would burn out.
When the panel was replaced with breakers once a month or so the breaker would trip when the fridge compressor would start while the microwave was running...
Old 10-01-2011, 05:48 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,970
Most newer microwaves are 900-1200W, or even 1400W - and that's the magnetron output. The input power is ~50% more than that.
mpoulton is offline   Reply With Quote
Old 10-01-2011, 05:50 PM   #9
Code05's Avatar
I do not have a clue about whatever was going on at your grandmother's.
Yes, your numbers of around 2000 watts total will probably not trip a 15 amp breaker. This assumes this is the total load. Inrush is way too short to trip it.
Old 10-03-2011, 10:58 AM   #10
When we upgraded from 100 amp to 200 amp service, the electrician put both the fridge and dishwasher each on their own 20 amp circuit.
brgmgb is offline   Reply With Quote
Brain Lock, help a guy out Bigfoot Electrical 13 06-02-2009 08:08 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 08:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 07:13 PM
