Old 03-09-2009, 01:41 PM   #1
Refinishing a basement room
Going to replace the paneling, ceiling tiles with drywall and add more outlets (several computers in the room and Television/DVD/VCR etc.) I would also like to get rid of the track lighting and put in 6 recessed lights as well as 2 simple (40-60 watt) lights in the closet. Currently when I run my laser printer the lights go dim in the room. There is not a dedicated circuit to this room since it is an old house (1950) however we do have a 200 amp circuit panel with numerous empty slots as it was upgraded a few years ago before we bought the house. MY question: Can I run a 15 amp circuit using 14/2 for the recessed lighting and the closet lights, and then a 20 amp circuit using 12/2 to about 6 outlets maybe 2 of those being "double" outlets. I just think it would be too much to run the lighting and computer off the same circuit since I am already having dimming problems currently. This is a Minnesota residence.
jacads is offline   Reply With Quote
Old 03-09-2009, 02:32 PM   #2
Send a message via AIM to Bocolo
Sounds good. I believe most people prefer to run 14/2 for lights and 12/2 for receptacles. You just can't combine the two and if you do then you can only put them on 15 amps. Don't quote me on this but as long as you have less than 12 outlets on a circuit you should be OK. You have more knowledgeable guys than me in here, give it a few minutes and I am sure they will chime in.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 03-09-2009, 02:44 PM   #3
How many computers and what is the average wattage of them?
Total load of the tv system?
What is the pull of the laser printer?
Estimate loads are ok...I'm not sure how you can fit all of that stuff on a 20 unless they are small...
rgsgww is offline   Reply With Quote
Old 03-09-2009, 03:13 PM   #4
Remodeling Contractor
14/2 is fine for the lights. 12/2 is fine for the outlets. But I would use another circuit for the computer and use a APC surge suppressor. The printer cannot be plugged into the surge suppressor, so use a double duplex outlet in this area.
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
Mysterious Basement Leak MidTenn General Discussion 4 08-31-2008 03:20 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Basement Remodeling Help DMonkey6972 General Discussion 5 01-15-2007 01:35 PM
