Reducing The Heat. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2005, 03:22 PM   #1
Reducing the heat.
Can you tell me if I can a hair drier into a outlet controlled by a dimmer to reduce the heat flow, safely? :confused:
Talman48 is offline   Reply With Quote
Old 10-25-2005, 04:17 PM   #2
I vote no. Instructions on a light dimmer would probably say the same. I don't think a motor control reostat would work either. Hopefully some more experienced guys will be along here soon. HS.
K2eoj is offline   Reply With Quote
Old 10-25-2005, 09:14 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
The answer is no. As stated by hammerslammer. Using a dimmer on an outlet is against code. If you want less heat, buy a less powerful hairdryer!
heat wont come on with t-stat in auto wahanks HVAC 5 02-07-2014 10:08 AM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
heat pump not working kyleGR HVAC 2 05-30-2006 02:35 PM
