Redo??? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 07:58 PM   #1
ericmunyon12345's Avatar
Redo???
Ok, a friend retired my garage. The plugs (2) are gcfi protected. The lights (including exterior food light) and plug in the rafters (for the door opener which is new) are NOT gfci protected. He didn't want the opener to trip the gfci, which it shouldn't, or the lights to kill. All the wiring is good, but I know technically the whole garage should be gfci protected. It wouldn't take too much to change a few connections and have it all protected through the load on the gfci plug. Should I do it, or don't bother for just lights and door opener?
ericmunyon12345 is offline   Reply With Quote
Old 03-03-2013, 08:08 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Depending on what code cycle you are on, technically, the entire garage does NOT need to be GFCI protected.
Old 03-03-2013, 08:10 PM   #3
Master Electrician
Rewards Points: 3,870
Lighting does not need GFCI protection. simply install another GFCI for thr door operator.
brric is online now   Reply With Quote
Old 03-03-2013, 08:12 PM   #4
Rewards Points: 13,712
Your post makes almost no since, but the only thing that needs to be GFI protected is the outside and inside lower outlets.
The ones for the garage door opener do not need to be GFI protected.
Not going to do any harm if they are though.
A circut breaker protects from an over loaded circut, a GFI protects againt an unbalanced circut. It's not going to trip just because a garage door kicks in.
http://home.howstuffworks.com/question117.htm
Old 03-03-2013, 08:31 PM   #5
E2 Electrician
This entirely depends on what code cycle the OP is on....
The Following User Says Thank You to stickboy1375 For This Useful Post:
brric (03-04-2013)
Old 03-03-2013, 08:45 PM   #6
Licensed electrician
Rewards Points: 1,622
The exception for single receptacles and ceiling mounted one not to have GFI protection has been removed in the 08 an 11 NEC. The protection needs to be readily accessible.
Old 03-03-2013, 08:46 PM   #7
No idea, and couldn't just find in a search. I'm in SW Michigan. Berrien Co.
Old 03-03-2013, 08:49 PM   #8
Sorry, to be clear, are you saying the rafter outlet IS now required to be gfci? Thanks.
Old 03-03-2013, 08:52 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
According to the map I have Michigan is on the 2008 code cycle and ALL garage receptacles would need GFI protection.
The Following User Says Thank You to k_buz For This Useful Post:
ericmunyon12345 (03-03-2013)
Old 03-03-2013, 08:53 PM   #10
E2 Electrician
It is, but as said earlier you may not have this requirement depending on what code cycle your state has adopted, but for simplicity sakes, since you are concerned to begin with, just install a GFCI breaker and feel safe again.
Old 03-03-2013, 08:58 PM   #11
Yes, the 08 states that all 15 and 20 amp 120 volt receptacles have GFI protection.
need to redo some type B venting that has screws amakarevic HVAC 3 07-15-2011 09:30 PM
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 10:35 PM
Looking to redo plain oak cabinets from 1991. Help?? Rhizzlebop Carpentry 27 09-16-2009 11:14 AM
Bathroom ReDo From GA. gilj Remodeling 4 06-02-2009 09:12 PM
Bathroom Redo 2008! manofthehill Remodeling 3 08-12-2007 12:10 PM
