Old 06-05-2012, 11:29 AM   #1
red outlet in garage
I have one 110 v outlet in my garage that is red, why?
Fatty is offline   Reply With Quote
Old 06-05-2012, 11:33 AM   #2
It normally means that it's supplied by emergency power such as a generator. Or someone just happened to have a red one and thought it looked cool.
zappa is offline   Reply With Quote
Old 06-05-2012, 02:25 PM   #3
joed's Avatar
In a house I go with second option. Or they worked in a hospital and took one home to use.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 06-05-2012, 02:29 PM   #4
Idiot Emeritus
Both the posts above are correct.
In a hospital, in patient care rooms, all switches and receptacles that are supplied by the life-safety system are required to be red. This is not in the NEC, it's a hospital certification requirement.
A lot of commercial/industrial buildings I work on use red for switches and receptacles that are supplied by a generator when utility power is out.
Rob
micromind is offline   Reply With Quote
Old 06-05-2012, 02:52 PM   #5
Is it wired in any unusual way, for example is not live unless an extension cord is pressed onto a set of prongs (male receptacle; inlet) in an outlet box somewhere else in the house?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 12:02 PM
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 08:07 AM
Switched Outlet Issue mjm Electrical 11 01-23-2011 08:41 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
