Rectangualr, Three Pin Plug In Baseboard - Purpose? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 03:57 PM   #1
Rewards Points: 81
Rectangualr, Three Pin Plug in Baseboard - Purpose?
I have often wondered over the last 20 years what these connectors are for in my baseboards. It is a 1956 ranch in the Detroit area. The basement ceiling is finished with interlocking tiles, so ripping it down to trace the wires was never a desired option.
There is what looks to be about 18 gauge stranded lamp cord or speaker wire connected to the screw terminals on the back. This one came from the dining area of the living room. There was a second one about 8 feet away on the same wall, which is directly under the only phone jack that was in the house. There are also a couple in the bedrooms.
Were these old style phone connections? 1950s surround sound wiring?
tev9999 is offline   Reply With Quote
Old 12-09-2012, 04:08 PM   #2
Phone were 4 wire in a square.
It looks like an old TV antenna plug.
1950home is offline   Reply With Quote
Old 12-09-2012, 04:23 PM   #3
TTW
TTW's Avatar
Yep, those were tv antenna plugs.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-09-2012, 04:42 PM   #4
Rewards Points: 81
Mystery solved. Thanks. It does seem strange that they had two installed on the same wall in the dining area.
Old 12-09-2012, 05:00 PM   #5
Oso954's Avatar
Rewards Points: 414
1950s surround sound wiring ?
That's a good one - I really enjoyed that.
Oso954 is online now   Reply With Quote
240 Cadet heater plug question 4k watt sharky74 Electrical 2 11-18-2012 10:41 PM
Light switch controls 1 the wall plug but both top and bottom plug. edewater Electrical 1 10-09-2012 03:31 PM
baseboard power outlets amakarevic Electrical 19 09-16-2012 10:32 AM
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 04:39 AM
Converting hard-wired baseboard heater to plug Mia Electrical 5 01-02-2010 04:16 PM
