Recommendations For Installing Receptacles In Shallow Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2010, 07:27 PM   #1
recommendations for installing receptacles in shallow wall
Ok im wondering how i can run wire to some new receptacles on this length of wall....as you can see i have minimal room behind the plasterboard to install some standard size receptacle boxes...i wanted to use shallow boxes but those require the wire to be stapled before entering the box...am i stuck with running raceway here?
joseph2293 is offline   Reply With Quote
Old 02-25-2010, 07:42 PM   #2
Learning by Doing
Leah Frances's Avatar
What's behind the wall? Concrete? Brick? Fortress of Solitude? I cold chiseled out a brick wall behind some wood paneling so I could get deeper boxes in. Good thing it was softer brick - the mortar was harder than the brick.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-25-2010, 07:53 PM   #3
its the basement concrete wall...
Old 02-25-2010, 08:18 PM   #4
Learning by Doing
Ok, your solution then is to build out for your deeper rec., put some trim around it and make it look nice and custom.
Old 02-25-2010, 08:40 PM   #5
I knew you guys would come through...even if it sticks out maybe half an inch...its still better than having raceway all over the wall...thanks!
Old 02-25-2010, 09:52 PM   #6
Rewards Points: 1,016
Fished retrofitted NM does not have to be stapled, methinks.
Old 02-25-2010, 11:29 PM   #7
Shallow boxes require stapling? What about a shallow retrofit? I don't have the instructions handy but I'm not sure how a retrofit box could require stapling.
Google "carlon b108r" and check that out maybe?
brich is offline   Reply With Quote
Old 02-26-2010, 09:58 AM   #8
I was looking for shallow re-model boxes but couldn't find any...the only ones i could find were some that you have to screw into your mounting surface...inside the box it stated that the wire had to be stapled...but now that i know there are re-model shallow boxes i will have to get some...good stuff!
Old 02-26-2010, 10:33 AM   #9
Licensed electrician
Rewards Points: 1,258
Standard metal 4 square boxes are 1 1/2" deep, add a flat one gang plate. You can screw thru the back of the box into plastic anchors.
Be sure to make a shallow hole for the ground screw.
Old 02-26-2010, 01:04 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
Carlon box B117RSW
Page six of the catalog.
Seen here.http://www.acehardwareoutlet.com/(oj...?SKU=998007302
Old 02-26-2010, 09:22 PM   #11
Household Handyman
Rewards Points: 1,408
"You can screw thru the back of the box into plastic anchors."
Isn't that an NEC violation? Correct me if I'm wrong, gently please. Won't this leave "exposed screw/fastener" heads within the box? David
Old 02-26-2010, 09:56 PM   #12
" Euro " electrician
frenchelectrican's Avatar
No useally not a NEC violations at all and it is common to do that with metal j boxes plus a bit of plastique boxes as well so it is NOT a issue ditto with earth screw { green grounding screw } as long you do not leave anything sharp inside the box you are ok.
And the other tip here with 1.5 inch 4 X4 boxes when you bring in the conductor or cable try to run in off centre so that way you don't really have to " fight " with the conductor or cable comming in centre knockout opening so keep it in your mind with it.
Merci.
Marc
Old 02-26-2010, 10:47 PM   #13
Well I saw one that had better trim then this at one point
But I can't find it
The one I saw had fancy trim around the edge of the flat trim shown
It looked really nice once painted
Old 02-27-2010, 07:28 AM   #14
Licensed Electrician
Merci.
Marc
As Marc said. Not a problem. Also remember that you can't use mounting screws for attachment of ground wires. Have to use a listed means for attaching those.
Tuckahoe Sparkplug is offline   Reply With Quote
Old 02-27-2010, 08:28 AM   #15
But I can't find it
this looks like the best option because i think the shallow remodel box was still to deep...if you look in the picture i only have about 1-1/4" to work with and thats from the concrete wall to the outer surface of the plasterboard...i think with some rounded edges this could look pretty nice! i could even match the stain with the current wood trim! can you tell im excited? ; )
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Loads on a partition wall acyate Building & Construction 8 03-01-2009 12:02 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
