Recommendations For A Home Welding Machine - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 07:39 AM   #1
FlyingHammer
Recommendations for a home welding machine
Looking for recommendations on a general-purpose home welder. I'm a complete novice with welding, but pretty handy otherwise. I just need to be able to do some occasional repairs and possibly some light fabrication. I need something relatively easy to operate/maintain and not too expensive. What type of welder should I be looking at? I have a 220 outlet available in the garage.
FlyingHammer is offline   Reply With Quote
Old 01-28-2011, 07:45 AM   #2
Just call me Andrew
Rewards Points: 1,020
You have to make sure your outlet on a circuit with the proper amperage for whatever welder you buy. Just the fact that it's 240v is not enough info.
As far as a recommendation, you're probably better off posting in the tools forum.
Andrew
secutanudu is offline   Reply With Quote
Old 01-28-2011, 07:50 AM   #3
FlyingHammer
50A breaker & #6 wire to the outlet.
Old 01-28-2011, 01:34 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,970
The venerable Lincoln AC-225 is a good piece of equipment to have around. It's indestructible, easy to use, and cheap. Your 50A circuit is just right.
If you want more capability and versatility, you might want to consider a MIG setup. I'd recommend something like a Millermatic 180 or 252. The Passport is great, but very expensive if you don't specifically require portability.
mpoulton is online now   Reply With Quote
Old 01-28-2011, 03:13 PM   #5
Do you have to plug it in? Kohler makes some real nice generator/arc welder units. In my opinion the older ones if you can find them are better.
Dwoodsmith is offline   Reply With Quote
Old 01-28-2011, 03:43 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,632
Ayuh,... I posted in this redundant thread about the same question, by the same poster...
A 110v wirefeed, 140amp is a Great starter unit, 'n can be found reasonably Cheap,...
It'll faithfully weld material up to 3/16ths"...
If you future includes weldin' heavier materials,...
A 220v stick machine, aka, Buzzbox, is the way to go...
Goin' up to a 220v Stick machine, with Ac/ Dc opens the way for many more Specialty rods...
Bondo is online now   Reply With Quote
Old 01-28-2011, 04:03 PM   #7
MikeKy55's Avatar
Rewards Points: 254
I have a LIncoln Weldpac 100 wire feed that I added gas to make it a mig. It's does fine up to say 1/8", but after that it's not that great. It's a 110V machine. I bought it when I was building my 55 Chevy so I didn't have to keep hauling my brothers machine back and forth every weekend.
MikeKy55 is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General DIY Discussions 2 11-14-2008 07:43 PM
Home Addition destepan Building & Construction 6 12-05-2007 12:28 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
