Recommendations For Dimmable Under Cabinet Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 09:27 PM   #1
Recommendations for Dimmable Under Cabinet lights
Just remodeled my kitchen and now at the point to install some under cabinet lights. I had ran an extra romex line with the intention of using it for the cabinet lights on a lutron dimmer.
I did google some forum discussions, but they were a few years old. I'm sure better products has been released since then.
Led's preferable, but will also consider xenon if they led's can not be harwired with a dimmer. I need about 7'.
drex is offline   Reply With Quote
Old 04-22-2012, 10:08 PM   #2
Missouri Bound's Avatar
Standard puck lights are dimmable. They commonly use a 12v transformer. Either an inline dimmer or a dedicated outlet for the lights with a wall dimmer.
Do you want it your way or the right way?
Old 04-22-2012, 10:14 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I prefer some "standard", hardwired xenon lights.
Old 04-22-2012, 10:32 PM   #4
Julius793's Avatar
led's all the way
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 04-23-2012, 10:25 AM   #5
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Isn't it "bad" to dim the outlet if a transformer is plugged into it?
hyunelan2 is offline   Reply With Quote
Help with replacing under cabinet lights miami mama Electrical 4 10-20-2011 11:03 PM
Want to make under cabinet lights right Dshow Electrical 3 06-23-2011 08:49 PM
Under cabinet Lights? kcrossley2 Electrical 44 06-27-2010 12:14 PM
under cabinet lights Barry J Electrical 3 07-05-2009 11:07 AM
