Recommend Single Box Control For Bath Fan/light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 06:58 AM   #1
Recommend single box control for bath fan/light
For a regular old Nutone, Hunter, or Broan vent-fan-with-light combo, what do you recommend for a single-box control that can operate the light, and operate the fan with an auto-turn-off of some kind?
JohnstownFlood is offline   Reply With Quote
Old 03-31-2011, 07:26 AM   #2
Licensed electrician
Rewards Points: 1,472
If the fan is on the same switch as the light people will turn the fan off before all the humidity can be exhausted. You also may not want the fan on just because you need light. I prefer single switches for each.
Old 03-31-2011, 10:56 AM   #3
I think you missed what the OP is saying. He wants separate controls for the fan and light, but I think he's saying he only has a single gang box.
The only thing I could find that matches what you describe is a dimmer/timer combo, which is costly, and won't work if you want to use CFL light bulbs.
http://www.amazon.com/Lutron-MA-L3T2...1586901&sr=8-2
DetroitEE is offline   Reply With Quote
Old 03-31-2011, 04:22 PM   #4
My suggestion is to either forego the timer you want and settle for a stack switch, or replace the single gang box with a 2 gang box.
Rick
http://myhandyadvice.blogspot.com/
sharpsport is offline   Reply With Quote
Old 03-31-2011, 06:10 PM   #5
Journeyman Wireman
Rewards Points: 150
Lutron makes a variety of stacked switches.
dimmer/timer combo
http://www.dimndimmer.com/ma-l3t251hw-wh.html
general links to stacked control list
http://www.dimndimmer.com/designer-o...-switches.html
Jupe Blue is offline   Reply With Quote
3 way, 4 way, Single Pole/3-Way Combinations slash5bmw Electrical 5 06-22-2010 07:21 AM
Fan/Light switch ibweis Electrical 3 01-21-2010 07:53 AM
Ceiling Fan Speed Control czars HVAC 0 01-14-2010 08:06 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Stanadyne single control showe faucet medina exc Plumbing 1 05-19-2008 05:03 PM
