Recharging A Rechargable Battery - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 11:18 AM   #1
Rewards Points: 121
Recharging a Rechargable Battery
Hey All,
I got (3) Power Sonic 6 Volt 12Ah rechargeable batteries (Model #PS-6100 F2)
I got these from a friend who removed them from a demoed emergency light fixture. I use these for testing various electrical components (car, electronics, etc.) that I work on.
Is there anyway I can get a recharger than I can plug into a 120v Outlet and attach leads to the 2 top post terminals.
Any help/links would be appreciated.
Thanks!
icepal1999 is offline   Reply With Quote
Old 05-23-2013, 12:08 PM   #2
Electrician
Rewards Points: 150
Auto/vintage/motorcycle chargers can come with a 6 volt setting.
Example:
http://www.sears.com/plus-start-batt...&blockType=G12
The slower you charge these batteries the longer they'll last. 2 amps may even be too much. Look for the words trickle charge.
Also look for float charge or three stage charger, if possible.
Glennsparky is offline   Reply With Quote
Old 05-23-2013, 12:21 PM   #3
Rewards Points: 3,130
Buy a cheap motorcycle battery charger. Mine has a switch for 6 or 12 volts.
Old 05-23-2013, 09:37 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,100
Originally Posted by icepal1999 View Post
Hey All,
Thanks!
The ideal charging would be 1/10AH,
so if 12AH = 1.2A for about 14 hours.
It wont need 1.2 amps for the full 14 hours,
as it will drop off as the charge comes up.
so if you can find a wall wart to supply about 8 volts at 1.2amps
you will be fine.
Its an odd voltage, so an adjustable power supply could
be the go.
But I think it would be easier to find a cheap battery charger
at a discount car supply store.
dmxtothemax is offline   Reply With Quote
Old 05-30-2013, 08:20 AM   #5
Yeah you can think to buy for a cheap Battery charger that can fulfill your requirement. Lot of sources are available for this. Otherwise checkout http://wagawoo.com/battery-chargers hope it will help you a lot.
jacques1 is offline   Reply With Quote
Rechargable battery question jonnyb Electrical 4 09-17-2012 09:26 PM
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 06:40 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 02:31 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 06:34 PM
