Recessing Electric Range Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 08:33 PM   #1
Recessing electric range outlet
Hi all:
Question in preparing for next weekend's project.
I have a Kenmore electric range (about 5 years old) that doesn't sit flush against the wall and thus sticks out past the counter slightly. I'm pretty sure the situation is that the plug juts out so doens't let the oven go all the way back to the wall.
I'd like to replace the existing box/faceplate with a recessed arrangement.
Is there a particular product someone can recommend to fit this arrangement and anything wierd I should expect beyond what replacing a box and outlet would normally entail?
Thanks!
schnitz411 is offline   Reply With Quote
Old 03-22-2010, 09:31 PM   #2
Journeyman Wireman
Rewards Points: 150
Have you pulled the range out to see if the cord is keeping it from sitting against the wall? Is the range receptacle a surface mount or flush mount? Can you post a picture?
Jupe Blue is offline   Reply With Quote
Old 03-22-2010, 09:53 PM   #3
OK now that I pulled it out to get a picture I see more and I'm guessing it gets more complicated.
it looks like the Romex-type cable comes out of the wall and is surrounded by a ring/buffer/cushion around the hole of Styrofoam peanut type stuff and then runs into a box which is just lying on the floor. the plug goes into the that box.
Pictures from down the back and straight at the floor level attached.
So basically there appears to be NO wallbox....
Recessing electric range outlet-img_0811.jpg   Recessing electric range outlet-img_0810.jpg   Recessing electric range outlet-img_0809.jpg
Old 03-22-2010, 09:58 PM   #4
Electrician
Rewards Points: 760
You may be able to surface mount a box close to the floor, and plug it in there. Some stoves have a small space(behind the drawer) that is enough room to accomate this and allow you to push the stove right back to the wall.
darren is offline   Reply With Quote
Old 03-22-2010, 10:03 PM   #5
The drawer has plenty of room behind it...the problem seems to be the stupid way the line comes in with the insulation around it about 2/3 of the way up.
So basically cut a hole near the floor, feed back the cable from the existing loose box into the wall, patch/strip out the strofoam, and pull the cab;le back down to come out near the floor. At that point I can surface mount or even just re-attach to the exisitng box that is sitting on the floor anyhow. And since its permanently behind the oven, it doesn't need to look pretty.
Is the box loose on floor arrangement even code-compliant?
Old 03-22-2010, 10:23 PM   #6
Journeyman Wireman
Rewards Points: 150
It looks like you have enough length in the cable to cut in a 2 gang box and install a flush mount receptacle. You would need to cut away the spray foam insulation (hopefully they only foamed around the cable and didn't fill the cavity) and work the cable loose. Then cut the hole for the box, feed the cable out of that hole and into the box. Then install the receptacle. I would cut the hole for the box as close to the floor as possible.
You would also need to patch the hole that the cable is now exiting from.
The Following User Says Thank You to Jupe Blue For This Useful Post:
schnitz411 (03-22-2010)
Old 03-22-2010, 10:26 PM   #7
Thanks! I'll be back this weekend if I run into trouble, but looks do-able.
Old 03-23-2010, 02:00 AM   #8
" Euro " electrician
frenchelectrican's Avatar
You can able get two gang box mounted in the wall however keep in your mind do not get shallow box at all due you have either 10mm˛ or 16mm˛ { #8 or #6 AWG respectally } and most home the studs are spaced 16inches on centre and some case you may have something in the wall it may block the location where you want the recetple to be installed.
Normally 90% of the time I do install the range recetpale with ground pin up but few case you may have to turn it to side { 4X4 steel box with two gang mud ring can do this very easy but plastique boxes naw you will have to make a hortzonal stud to support it}
Merci,Marc
Old 03-23-2010, 08:49 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I would just cut a channel in the wall to push the cable into. Cut it down to the space behind the drawer. Push the cable into the channel Leave the existing surface mounted receptacle.
Coastal South Carolina
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 06:39 AM
Range outlet required? A for Effort Electrical 6 07-21-2009 08:15 PM
Replace Range Outlet Suncrest79 Electrical 22 04-15-2009 12:32 AM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 07:01 PM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 11:11 PM
