Recessed Outdoor Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2005, 11:37 AM   #1
Recessed Outdoor light fixture
I have an awning over my side door. I see hanging ceiling fixtures at my local stores, but I need a recessed light so a screen door will clear. Do I have to use a specific type of light fixture outdoors ?
Thanks,
Scott
Scott_K is offline   Reply With Quote
Old 04-05-2005, 01:48 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
Do you have room above to install a recessed light? It should be ok as long as you have the room and have a roof over it
jbfan is online now   Reply With Quote
Old 04-05-2005, 02:36 PM   #3
Thanks for the response.
Yes, there is room for it. The awning is about 4'x4', already has an existing feed and switch. So I guess I can just use a highhat that I'd use indoors ? :confused:
Thanks again
Old 04-05-2005, 03:10 PM   #4
jbfan's Avatar
Rewards Points: 546
is this an added awning or is it built with the house?
Old 04-05-2005, 03:46 PM   #5
Sorry, let me back up a bit.
There was an original awning in place over the side door. It had a light and switch and worked. I recently had some work done in the house, and in the process, the contractors damaged it, so they replaced it with this new one and left a line there for a light. It sticks out of the side of the house, so there is no other roof, mansard or whatever they're called connected to it. It's got siding and shingles, so it's protected from the elements.
Does this make sense ?
Thanks Again
Old 04-05-2005, 04:04 PM   #6
jbfan's Avatar
Rewards Points: 546
Yes. When I think of an awning, I think of a metal frame and cloth to cover it with, This will be ok to do.
Old 04-05-2005, 04:53 PM   #7
jbfan, Thanks for all your help and your fast responses !!!:D
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 04:42 PM
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 03:55 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
