Recessed Lights In Exterior Soffits - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2013, 01:15 AM   #1
Rewards Points: 518
Recessed lights in exterior soffits
Do recessed pot light fixtures installed into aluminum soffits needs to be IC or non-IC?
n0c7 is offline   Reply With Quote
Old 07-01-2013, 04:21 AM   #2
Electrical Contractor
kbsparky's Avatar
It's highly doubtful that your soffits are insulated.
Either IC or non-IC rated cans should be fine.
HOWEVER, you should be more concerned with using fixtures that are listed for use in damp or wet locations.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
ddawg16 (07-01-2013)
Old 07-01-2013, 10:40 AM   #3
Rewards Points: 518
It's a new garage I'm building myself. The attic will be insulated but the soffits kept clear with cardboard baffles.
I bought IC rated suitable for indoor/outdoor and damp locations at Lowes. JUNO brand I believe. This sound ok?
Old 07-01-2013, 10:47 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
I think I know the ones your talking about....are they the smaller ones with the integrated trim or larger where you can select your own trim?
I have some outside on my garage...not insulted (we don't have the 'temp' issues you do). The only issue is that condensation will collect on the trim...if it's not intended for outdoor/damp use...it will rust.
Also...I would plan on LED's in them....yea, they cost more but you don't have to worry about changing them or temp problems. I'm using CFL's....
Old 07-02-2013, 11:30 PM   #5
Rewards Points: 518
Larger ones you can select your own trim.
http://www.lowes.ca/recessed-can-lig...ductItemsImage
Kind of expensive since it's $20.96 per light and you still have to buy the trim and bulbs.
Old 07-03-2013, 12:20 AM   #6
JOATMON
ddawg16's Avatar
Halo has another ver that is IC....and if you buy the contractor box....works out to about $8/fixture....
Old 07-03-2013, 06:25 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Either will work. I'm not sure what you got for $20 though. Might be air-tites.
Halo H7ICT should be around $7 for the can and another $10 for the trim. I can't imagine Juno being much more.
The trims on those contractor pack lights are junk. I can't imagine they'd last long outdoors.
Recessed lights: What are the differences between LED trims and LED modules? htabbas Electrical 7 11-27-2011 10:54 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 01:58 AM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
How many recessed lights in small bedroom? cdcamaro9534 Electrical 1 01-08-2009 09:57 PM
