Recessed Lights / Box Volume Size - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 10:52 AM   #1
Question
Hey,
I'm located in Ontario/Canada and I'm in the process of installing some recessed lights in my uninsulated basement. I was going through the electrical code and noticed that in an 8in^3 electrical box, it is only permitted to have 2 wires and 2 wire nuts.
I have 3 wire nuts (ground, neutral and hot) and two wires coming into each switch.
It seams odd that the light box would not be sized correctly considering its CSA approved. Have any of you come across a similar problem ?
As a side note, I'm also finding it hard to jam 6-8in of cable and 3 wire nuts in this small box !
GeorgesAA is offline   Reply With Quote
Tags
box volume , pot lights , recessed lights , wire nut
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Commercial Electric vs. Halo recessed lights bubbler Electrical 0 10-12-2011 08:06 PM
Adding recessed lights in basement tbone2004 Electrical 8 05-11-2011 11:19 AM
Adding new circuit for recessed lights.... DickieFL Electrical 7 11-21-2009 09:12 PM
Recessed Lights problem Boycer88 Electrical 15 02-01-2009 08:23 PM
