Recessed Lights In The Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 10:45 AM   #1
Rewards Points: 1,634
Recessed lights in the bathroom
I am going to install some recessed lights in the bathroom. Ceiling is down so I have full access.
After some searches I have decided to get three 4" lights.
Normally I prefer HALO products such as the H99, but I don't like their "damp location" trims. I looked around and this one by Lithonia caught my eye.
http://www.homedepot.com/p/Lithonia-...5#.UZZNgUpXqMs
The trim is very clean and nice, and the cost is attractive too.
So I went to Home Depot and looked at it up close and I have a few concerns.
(1) Since my sheet rock is down I want to put these in with new construction housing. The Lithonia housing do not come in new construction housing, they come in remodel housing as the standard package, then you buy an additional new construction "kit", which include the pan and the two sliding metal bars. Anyone used those? Any concerns with using a remodel housing with these kits?
(2) My framing is a bit different. Old house. The trusses are south yellow pine. Then they nailed in 1x3 wood furring across all the trusses and attached sheet rock to those furring strips. This means if I attach these metal bars for the housing to the bottom of the joists, the housing has to be lowered by an additional 3/4" to be flushed with the finished ceiling. I don't think it's a good idea to attach the metal bar ends to the skinny end of these 1x3s. I know the Halo cans you can slide the can up and down to account for different ceiling thicknesses. These cans seem not to support those. Any ideas?
(3) Anyone know of other 4" products that has a similar look at comparable prices? I saw one by Juno but the trim itself is $100+ not what I can afford.
Thanks.
miamicuse is online now   Reply With Quote
Old 05-17-2013, 11:05 AM   #2
JW
mm11's Avatar
Rewards Points: 614
Why not use the cans as old work?
Rough-in romex with whips as necessary where the lights will sit.
Before hanging ceiling, cut holes in rock where the lights go, put it up, and pull the whips through the pre-cut holes.
Wire cans, and seat them into the ceiling.
No new work retro-fit kits needed, and save yourself the time, hassle, and money of using the kits.
mm11 is offline   Reply With Quote
The Following User Says Thank You to mm11 For This Useful Post:
MTN REMODEL LLC (05-20-2013)
Old 05-17-2013, 03:26 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Are you kidding???? You honestly think that is less work than new-work cans??
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
brric (05-17-2013), gregzoll (05-17-2013), Philly Master (05-17-2013)
Old 05-17-2013, 03:27 PM   #4
Almost all trims are damp location. Do you mean wet location?
Where are you putting these cans that need a glass trim? Inside the shower/tub?
Old 05-17-2013, 03:45 PM   #5
Rewards Points: 1,192
Scab 2x3's on side of ceiling joists. Support recessed lights from them.
bobelectric is offline   Reply With Quote
Old 05-17-2013, 03:50 PM   #6
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Thanks.
6" is your best buy .....
2 over the vanity one in the shower ..
you only need "shower" trim over the shower not the rest of the bath ...
shower trims are funny "most" only a 40 watt bulb ....
new construction can is the way to go for this job ...IMHO ....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-17-2013, 07:40 PM   #7
I see what you mean. The problem is staging.
For this remodel I have over 60 ceiling fixtures (some recessed, some 6", some 4", some regular boxes for non-recessed fixtures. On top of that boxes on walls. I am doing the electrical part myself and getting everything installed, then I will hire out the sheetrock work.
If I do it as old work, then I need to be present and mindful when the rockers are here and do their thing. My preference would be to get all that out of the way, test stuff out then let the rockers do their job.
Old 05-17-2013, 07:43 PM   #8
Not inside the shower, but the ceiling will get wet from the moisture.
I forgot to mention I am in South Florida, where it gets to 120% humidity in the summer, and after I take a shower, even with a high power exhaust fan, the ceiling is moist. I have flush mount light fixtures way outside the shower area that the metal start rusting like 1 month after installation.
Old 05-17-2013, 07:47 PM   #9
I am using HALO 6" trims everywhere EXCEPT hallways and bathrooms.
In hallways the 6" trims look too big, so I used H99T and the 993W trim.
Obviously in the bathroom I can't use the open trim. It's more a look preference than a functional preference.
Old 05-17-2013, 08:14 PM   #10
Master Electrician
Rewards Points: 3,874
Are any of these installations going to be in contact with insulation?
brric is offline   Reply With Quote
Old 05-17-2013, 08:26 PM   #11
No...or should I say, I will trim back the insulation 3" from the fixtures all around.
Old 05-17-2013, 08:46 PM   #12
Licensed electrician
Rewards Points: 1,622
Recessed lights over a vanity create very hard shadow lines on the face and under the chin. It is not the most flattering.
Speedy Petey (05-18-2013)
Old 05-17-2013, 08:54 PM   #13
Master Electrician
Personally, I would never install non-IC rated cans in an insulated location.
The Following User Says Thank You to brric For This Useful Post:
Jim Port (05-17-2013)
Old 05-17-2013, 09:05 PM   #14
You are right bricc, all that does is create a hole that the heated or cooled air will pass thru and run up the energy bill year round.
Old 05-18-2013, 07:02 AM   #15
NONE of these areas is a wet location.
A bathroom ceiling is a damp location. You can use pretty much any standard recessed/trim combo.
Even inside a shower is only considered a damp location unless the light is subject to shower spray.
Bathroom lights not fully powered tcfls2 Electrical 21 03-12-2013 10:46 PM
Adding Additional Recessed lights to existing jay235 Electrical 5 11-08-2012 05:43 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
IC recessed lights getting hot? shockingsi Electrical 4 08-04-2011 12:56 AM
Bedroom Recessed Lights gregt848 Electrical 11 03-08-2010 04:07 PM
