Recessed Lights In Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 03:58 PM   #1
Recessed lights in basement
Hi,
I've installed can lights in my basement ceiling (between ceiling trusses) which are daisy chained together operating off 1 switch. However, the county inspector said that I had to provide access to all of the jucntion boxes or install can lights that allow access to the junction box from inside the can. I have searched the web high and low for such lights (6" and IC rated) and have not found any. If anybody has experience with such lights or know where I can purchase any or has installed can lights in there basement covered by drywall ceiling, I would greatly appreciate some advise as what to do.
Carl Ealy is offline   Reply With Quote
Old 04-13-2012, 04:14 PM   #2
Licensed electrician
Rewards Points: 1,766
Your inspector is lacking some knowledge. The junction boxes on new work housing are considered accessible. You remove the part of the housing that holds the socket.
Old 04-13-2012, 04:16 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Have a look here.
Some very qualified people touch on this subject.
Junction box in stud wall behind drywall?
sublime2 is offline   Reply With Quote
Old 04-13-2012, 04:41 PM   #4
yup. accessible means 'capable of being removed or exposed without damaging the building structure or finish or nor permanently closed in by the structure or finish of the building'.
unless you are cutting out drywall or similar, the boxes are accessible.
itsnotrequired is offline   Reply With Quote
Old 04-13-2012, 04:45 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Just a PITA to work on though!
Old 04-13-2012, 04:58 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Can you post a pic or link to the cans you used in your basement?
Old 04-13-2012, 05:20 PM   #7
Ok. I'll take a few pictures but they are Halo brand 6" ic rated can lights in approx. 3 x 4 rows.
Old 04-13-2012, 05:58 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Originally Posted by sublime2 View Post
Have a look here.
The discussion you cite has nothing to do with the OPs issue.
Coastal South Carolina
Old 04-13-2012, 06:12 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Lmao!
Maybe you should read through them all!
Junction box behind wall,has nothing to do with his issue?He failed inspection because there is no access to the boxes in the lights.
Really?
Old 04-13-2012, 09:58 PM   #10
Recessed lights only start to be discussed at post #56 in the thread linked to.
Old 04-13-2012, 10:25 PM   #11
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Correct.
That's why in my OP I stated that they "touch" on the subject.
Old 04-14-2012, 03:44 AM   #12
Rewards Points: 1,192
The inspector might be talking about other j-boxes in ceiling space.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
oh'mike (04-14-2012)
Old 04-14-2012, 10:13 AM   #13
Thanks Jim Port and all. Jim Port hit on the head. All I have to do is remove the 3 screws that adust the housing height and the whole housing slides down and out!
The Following User Says Thank You to Carl Ealy For This Useful Post:
sublime2 (04-14-2012)
Multiple recessed lights on two 3-way switches YellowBelly Electrical 6 11-27-2011 02:59 PM
Recessed lights: What are the differences between LED trims and LED modules? htabbas Electrical 7 11-27-2011 10:54 AM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 05:40 PM
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 01:58 AM
Lights For Basement Petrafire Electrical 6 07-11-2010 10:05 PM
