Recessed Lights Bad Install Needs A Fix - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 07:08 PM   #1
recessed lights bad install needs a fix
We installed dozens of recessed light cans to the appropriate levels based on the can instructions. Sheetrock was hung and now the cans are not able to make contact with the finish collars. We've tried pulling the cans down to no avail. Any suggustions? Is there a fix-it I can go buy?
tiredoftrying is offline   Reply With Quote
Old 06-28-2013, 07:21 PM   #2
Rewards Points: 13,690
No picture, no brand name of fixture mentioned.
So is the fixture flush with the sheetrock?
Any I've work with does not matter exactly where the fixture sits as long as it's not sticking out past the sheetrock, the springs pull the trim ring up tight to the ceiling.
Speedy Petey (06-28-2013)
Recessed lights in basement Carl Ealy Electrical 12 04-14-2012 10:13 AM
Multiple recessed lights on two 3-way switches YellowBelly Electrical 6 11-27-2011 02:59 PM
Recessed lights: What are the differences between LED trims and LED modules? htabbas Electrical 7 11-27-2011 10:54 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 04:20 PM
