Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 01:21 AM   #1
Recessed Lights
Is it OK if the housing of a Halo H7ICAT comes in contact with a wood joist? I know it's made to come in contact with insulation, but not sure about wood or other combustibles. Also, I'm planning to install 6 cans all about 4-5 feet apart. When I run the romex between cans in a daisy chain fashion, do I need to staple the romex somewhere between cans?
Thanks,
Goose
Goose1 is offline   Reply With Quote
Old 10-23-2010, 05:21 AM   #2
close to wood not a problem. It is always a good idea to staple wire if you have access, but not a necessity. If between floors, it is often impossible. Wires should be kept 1 1/4" away from surfaces where nails/screws may penetrate.
Old 10-24-2010, 11:05 PM   #3
Thanks Just Bill. That makes sense regarding the staples. I'll be in my attic to install the lights. Will one staple between lights be good enough?
How Many Recessed Lights SHould I use? jonathan03 Electrical 0 03-14-2010 11:03 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 04:20 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
