Old 06-11-2011, 09:42 AM   #1
Recessed Lights / 15 AMP Circuit
Could someone please let me know if I can run a total of 9 - 5" IC Halo Recessed Lights off a single dedicated 15 AMP Circuit? I plan on having having 3 lights per switch for total of 3 switches. I think that the light bulb is a BR30 which is 65 watts.
Also will I need to install an AFCI breaker for this? The circuit is pre-existing. What is everyone's thoughts on this new requirement? It will definetly add to the cost of any upgrade.
Thank you in advance for your advice.
ericm215 is offline   Reply With Quote
Old 06-11-2011, 09:46 AM   #2
Just call me Andrew
You said the circuit is pre-existing, but also that it will be dedicated. Did you remove what was on the circuit?
In any case, 65 watts x 9 = 585 watts
585 Watts / 120 = ~5 amps
You should be fine.
I don't think you need to add an afci breaker to an existing circuit. I could be wrong on that.
Andrew
secutanudu is offline   Reply With Quote
Old 06-11-2011, 09:46 AM   #3
Licensed electrician
The circuit size is based off the maximum bulb size that can be used in that fixture, not the installed bulb size.
IMO you are modifying the circuit and that would trigger the AFCI requirement.
Old 06-11-2011, 09:47 AM   #4
Andrew - Yes, there was only 1 65 watt light on that circuit and I removed it. Thanks for the quick reply.
Old 06-11-2011, 10:39 AM   #5
What room is this project in?
Old 06-11-2011, 01:41 PM   #6
This project will be in a converted sun room to family room. Thanks
Installing remodel recessed lights in manufactured home. MikeVila Electrical 14 08-03-2011 08:06 AM
How Many Recessed Lights SHould I use? jonathan03 Electrical 0 03-15-2010 12:03 AM
Bedroom Recessed Lights gregt848 Electrical 11 03-08-2010 05:07 PM
Adding a switch and new lights to a circuit? mj876 Electrical 5 03-07-2010 05:10 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 05:20 PM
