Recessed Lighting Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2006, 01:46 PM   #1
Recessed lighting wiring?
I want to replace two 8 x 8 inch square recessed lights in the family room. The wiring appears to be 2 wires with a cloth insulation. I am not familiar with this type of wiring. Can I connect a new recessed kit with these wires?
Kriv is offline   Reply With Quote
Old 10-17-2006, 02:01 PM   #2
the 2 wires you saw could be of a couple of cases... but in theory, recess light device just have 3 small wires to hoop up, a hot, a neutral and a ground, you can definitely replace the device with a new one, just make sure you connect it as exact same way as before... to avoid problem... you need to triple marks the wires before disconnecting in case you forget the configuration and damage your circuit when connecting them incorrectly afterward... and make sure you shut off the main panel before doing anything... shutting off the switch is not always good enough in two wires situation.... shut off at main panel will guarantee no electric shock...
KUIPORNG is offline   Reply With Quote
Old 10-17-2006, 03:21 PM   #3
Thanks for the info.
I wanted to put in a better 8x8 as a easy fix, but there don't seem to be any quality 8x8s out there. I guess I will have to go with something along the lines of a 6" round and fill in around the gap and repaint the ceiling.
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 03:52 PM
recessed lighting WIRING tj home Electrical 29 10-31-2006 08:50 AM
wiring for recessed lighting krw3153 Electrical 1 10-04-2005 02:39 PM
