Recessed Lighting Under A Deck - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 04:36 PM   #1
Recessed lighting under a deck
I want to put some recessed lights outside under my deck. The deck is a solid deck so its dry underneath. I have lights that are rated for damp locations but I was wondering about the wire. Do I need to used conduit if its all up in between the joists of the deck? Or can I just use regular indoor wire? The switch is inside and the wire will exit the interior of the house up in between the deck joists.
rovers1973 is offline   Reply With Quote
Old 11-11-2010, 11:17 AM   #2
Rewards Points: 64
Use UF cable. Inside wire (NM) is not allowed outside in damp or wet locations.
J. V. is online now   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
