Recessed Lighting: Trouble Routing To Switch! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 06:08 PM   #1
Question
Hello Everyone,
I am new to the DIY Chat Room, but have been a longtime reader before joining. My project consist of upgrading our basement and installing new lighting, new wiring and routing to a switch. In the room I am currently working on, there was 4 fluorescent shop lights spread over one large room of 12x24. I have built a wall in the center of this room to divide into two smaller rooms and have removed the 4 fluorescent lights.
I have added new 12/2 wire and upgraded to 8 recessed lights, but I would like to route the lights to one single pole switch, over two junction boxes. The switch is wired using 2 hots, Black and White for continuous and switched, but I am not sure what is the safest way of grouping the lights together and running to the switch. I have prepared a diagram for you to visualize what I am attempting to accomplish and hopefully this makes sense. I appreciate your comments and advice in advance.
SirFix-A-Lot is offline   Reply With Quote
Old 05-04-2013, 07:01 PM   #2
Electrical Contractor
kbsparky's Avatar
Do it like this:
Recessed Lighting: Trouble Routing To Switch!-light_diagram2.jpg
-KB
Old 05-05-2013, 06:16 AM   #3
Rewards Points: 2,516
Your way would functionally work but then no neutral would be at the switch location. If you never intend to add a motion sensor or a timer to replace the single pole switch oh well.
As a note you sure you would want all 8 lites on at any one time. Would Two switches be better??
Recessed Lighting: Trouble Routing To Switch!-new-bitmap-image.jpg
hammerlane is offline   Reply With Quote
Old 05-05-2013, 07:20 AM   #4
joed's Avatar
Rewards Points: 12,900
The original drawing will only work if the cable listed as feed between the two junction boxes is a 12/3.
Old 05-05-2013, 07:26 AM   #5
Licensed electrician
Rewards Points: 1,622
You do not need the additional junction boxes between the lights. Just go from switch to light to light to light.
Old 05-06-2013, 09:35 AM   #6
Rewards Points: 1,456
Yea, you're complicating that. Just run the power to the switch and then run the lines from light to light in a circle or whatever method uses the least material.
mikegp is offline   Reply With Quote
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Help wiring new recessed lighting nyad Electrical 7 06-10-2009 11:54 AM
