Recessed Lighting Trim Interchangability? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 02:04 PM   #1
Rewards Points: 180
Recessed lighting trim interchangability?
About a year ago I installed Utilitech recessed light cans in my basement. It's a slow moving project that I'm only just finishing now-the drywall, paint, and trim is done, and it's time to install the trim on the lights which I didn't buy at the time. I went to Lowes today to pick them up and was told that Lowes is phasing out Utilitech completely and they do not have the trims in stock anymore. Will the Juno/Halo trims fit? Is there some kind of "universal" trim? I'm not even looking for the baffled trims, just the simple rings that hide the edge of the can/the hole in the drywall.
Badfish740 is offline   Reply With Quote
Old 11-27-2012, 03:42 PM   #2
Oso954's Avatar
Rewards Points: 1,332
If they are the 6 inch cans, yes, the halo rings (e.g. 301P or similar) will fit.
Oso954 is offline   Reply With Quote
Old 11-27-2012, 03:49 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Personally, I wouldn't install any other trim then what is listed inside the can. Undesired results could occur.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
frenchelectrican (11-27-2012), Jim Port (11-27-2012)
Old 11-27-2012, 04:58 PM   #4
Oso954's Avatar
Personally, I would not have purchased a "big box knock-off" can to begin with.
This is only one of the problems you can run into with them.
Old 11-28-2012, 08:27 AM   #5
Rewards Points: 180
Thanks for the tip on the Halo trims, I'll pick some up this week. As for the "big box knock-off" cans, let's not pretend that they're not all made in the same Chinese factory and simply put into different boxes at the end of the assembly line
Old 11-28-2012, 01:39 PM   #6
Oso954's Avatar
Originally Posted by Badfish740 View Post
.... As for the "big box knock-off" cans, let's not pretend that they're not all made in the same Chinese factory and simply put into different boxes at the end of the assembly line
There is a difference, if you can't tell it, that is your problem.
You never confirmed the 6 inch cans, just implied it. The reason I specified 6 inch is because if you have the 4 inch Utilitech, the Halo trims will not work.
Good luck when you have your first part failure.
bedroom recessed lighting advice wanted andrewbp Remodeling 2 09-30-2011 09:11 AM
Recessed Lighting on Sloped Ceiling-Need Help HandyFrank Electrical 0 09-23-2011 03:37 PM
Recessed light trim not compatible S11D336B Electrical 8 09-11-2011 08:13 AM
Changing recessed lighting trim? argh Electrical 2 09-06-2010 08:13 PM
installing recessed lighting trim lwb1 Electrical 1 09-01-2010 08:43 PM
