Old 08-16-2012, 09:22 PM   #1
Question
Recessed lighting spacing suggestions.
I have a space that is 14'(but could go longer) long and 15'7" wide and a 8' ceiling in a basement, but has a slider so there is some extra light.
I want to install 4 to 6 cam lights. Leaning strongly towards 4.
I know I should have my lights 3' from a wall and 6' to 8' from each other.
So the problem is the width of the room at 15' 7" and 3' from walls that gets me to 9'7" away from each other.
Question:
Should I bring in my lights so they are 3' 9.5" from the wall to get to 8' or is 9'7" not that bad?
altja is offline   Reply With Quote
Old 08-16-2012, 09:25 PM   #2
Licensed Electrician
k_buz's Avatar
Bring em out from the wall.
Location...Location...Location
The Following User Says Thank You to k_buz For This Useful Post:
altja (08-16-2012)
Old 08-16-2012, 10:22 PM   #3
Licensed electrician
Fixture spacing depends on the mounting height, trim and bulb selection and beam spread.
Old 08-16-2012, 10:28 PM   #4
Master Electrician
a rough guideline to use is for 4" cans you go with a four foot spread, 6" cans a 6 foot spread. so on and so forth. trim and bulb are a huge factor. I put 4 5 inch 75w halogens in a 18 by 12 room and you can get a tan in there
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-16-2012, 11:01 PM   #5
What is the purpose of the room?
I have 16 6" recessed cans in my garage....but I have them positioned over the work bench and general work areas...
If you plan to have stuff against the wall but don't want the light directed on it...then space them accordingly
jeepdawg is offline   Reply With Quote
Old 08-16-2012, 11:36 PM   #6
It is a play room in the basement. I have 6" cams.
Old 08-16-2012, 11:37 PM   #7
k_buz's Avatar
Quad Overhead Cams...LOL
altja (08-16-2012)
Old 08-16-2012, 11:43 PM   #8
Thanks. I will take your suggestions. I appreciate the confirmation that it would be the right way to do it.
Old 08-17-2012, 01:03 PM   #9
Cool
I would also bring them out from the wall. It sounds like, with an 8' ceiling, you would be fine with just 4 lights (most recessed lights that I've installed have a fairly wide reaching beam). If they are all on the same circuit, I would think that 6 might be a bit bright for a room that size. If you have no other sources of lights (lamps etc.) then it would probably be fine. Good luck with your project!
Adam works with Airco Service, Oklahoma's HVAC and Electrical partners, and enjoys writing about home improvement and technology advancements.
ssparay is offline   Reply With Quote
Tags
light spacing
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 08:04 PM
LED recessed night lighting JakAHearts Electrical 6 06-10-2010 11:26 AM
Recessed light suggestions? vyjeff Electrical 1 04-27-2010 02:26 AM
Recessed lighting for 15 amp circuit jacads Electrical 5 03-12-2009 01:12 PM
Insulating IC recessed lighting. topher0524 General Discussion 4 02-10-2009 07:03 AM
