Recessed Lighting Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 11:00 AM   #1
recessed lighting question
I have a ceiling fan, where 1 light switch operates the fan another switch operates the light on ceiling fan. My question is can tap into the light wires on ceiling fan to power 4 4inch recessed lights?
Thanks Rick
gb4545 is offline   Reply With Quote
Old 12-16-2012, 11:39 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes. As long as the box is large enough.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 12-17-2012, 03:48 PM   #3
Could i get a little explanation the "box"?
Old 12-17-2012, 03:50 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The junction box that the fan/light is currently attached to. Is that box big enough to accommodate the additional wire you'll be adding.
sublime2 is offline   Reply With Quote
Old 12-17-2012, 03:54 PM   #5
Ah thanks thats the first thing I was going to do...climb up in itchy insulation.
Old 12-17-2012, 05:05 PM   #6
TTW
TTW's Avatar
The actual volume of a box determines the number of wires, clamps, and devices that are allowed in the box.
The reason for this, is that if you cram too much stuff in there, there will not be enough free air to dissipate heat.
This can cause a thermal runaway in the box and start a fire.
For the same reasons, there are limits on how many individual romexs' can be bundled together, or how many conductors can be in conduit.
If you look carefully at those blue boxes, the number and size of allowed conductors is actually marked right on them.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 11:23 AM
Recessed Lighting Layout - HELP foxwoods321 Electrical 12 02-24-2011 09:32 PM
What kind of recessed lighting and bulb? Sardinia Electrical 2 01-28-2011 11:03 AM
Recessed Lighting help/questions Sephora Electrical 1 09-30-2010 01:50 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
