Old 12-07-2008, 12:37 AM   #1
Question
Recessed lighting problem (a real tough one)
I have 4 Halo h5r1cat recessed lights in one room off one switch. They were working fine for the last 5 years. Then one bulb goes out and I replace it, it still doesn't work, try another bulb that I know works and it still doesn't work. The bulb is a 50w Halogen Flood PAR bulb.
The real tough one is that if I put a regular light bulb (the one that looks like the idea symbol), it works.
How crazy is that?
bavenda is offline   Reply With Quote
Old 12-07-2008, 07:28 AM   #2
joed's Avatar
Problem with the socket. The tab in the bottom of the socket is squished down and not touching the bulb.
Old 12-07-2008, 08:28 AM   #3
Eibwen
I agree with Joed and would check that first...
Had the same thing happen on a new fridge when the light bulb blew..
Tore it half apart looking for a bigger problem..
Sammy is offline   Reply With Quote
Old 12-07-2008, 08:00 PM   #4
Bingo!, the tab is pushed in and it would make sense why a connection is not made. Now the challenge is how to bend it back out. I tried needlenose pliers, I tried a fish hook, tiny screwdriver but they don't work. I need something very small in a L shaped to pull it back out.
Thank you for solving my mystery.
Old 12-07-2008, 11:11 PM   #5
I found a old dentist tool which pulled the tab out and it is fixed. Again, thanks so much to joed for his help.
Tags
bulb, recessed lighting
Recessed Fluorescent Lighting - how many bakerhouse Remodeling 2 05-13-2008 11:42 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-15-2007 12:08 AM
recessed lighting WIRING tj home Electrical 29 10-31-2006 08:50 AM
Recessed Lighting DEAN Electrical 1 01-19-2006 02:14 PM
