Recessed Lighting (pot Lights) - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 05:43 PM   #1
recessed lighting (pot lights)
I am doing a reno on my upstairs bathroom and putting pot lighting in a drop ceiling. I left the drywall on the old insulated ceiling and would like to know how far I have to drop the new ceiling? Better yet, How much clearance do I need from the top of the 50 watt GU 10 pot lights to the old ceiling?
Willi is offline   Reply With Quote
Old 01-14-2010, 06:12 PM   #2
Inspector/Instructor
codeone's Avatar
Depends if they are IC rated or not.
codeone is offline   Reply With Quote
Old 01-14-2010, 06:24 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
The clearances will be shown in whatever paperwork came with the lights.
You will not need IC cans in the drop ceiling.
Old 01-14-2010, 06:46 PM   #4
codeone's Avatar
Non IC rated usually require 3" at least from insulation or combustable surfaces.
Old 01-14-2010, 07:13 PM   #5
Unless he insulates the drop ceiling this will not be an issue. Right?
Old 01-14-2010, 07:28 PM   #6
codeone's Avatar
Most of the heat on the can still goes out the top. Might still be wise to stay with the clearances.You also would want to make sure not to have any flex ducts keep the clearance away from the cans. That 3" clearance is for heat dissapation.
Old 01-14-2010, 10:58 PM   #7
Thumbs up
Thanks guys, They are not ic rated and i will not be insulating the space (The insulation is in the ceiling above). I will build the drop low enough to have that 3" clearance from old drywall. Thanks again!!!
Tags
electrical , pot light , recessed lighting
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
